How Long did 1.3.20 take on the phantom itself
Discussion in 'Firmware' started by mmee1992, Aug 4, 2015.
  1. mmee1992
    My Phantom has been doing the beeping sequence for about 15 minutes and the status light on the gimbal is still flashing green and red. The gimbal just went limp and the aircraft status lights just went out. Should I stop and try again, or is everything okay?
  2. nextgeneric
    You could give it a while longer and then check the .txt file it generated.
    mmee1992 likes this.
  3. mmee1992
    The gimbal went limp and then it came back and looked like it was running through a test or something and then it fixed itself and the update was complete. Checked the text file and it says success.
  4. nextgeneric
    You should be all set then, I would say! If when you've got everything up and running and it shows you're on the correct version number within the app, than you're golden.
  5. Dronebow
    Texas
    FYI - the beep sequence of 1 long beep followed by 2 short beeps should mean the update is complete. It will do 4 short beeps while updating and then will go to the DD - D - D sequence to indicate it's done.
  6. ruitjerru
    My P3 showed a continious green/yellow light above the camera after 20 mins or so, waited 5 more to be sure, switched off and checked log file, it says succes and 5-6 times abort because firmware is the same as the one installed.
    Conclusion, once the lights stop blinking the update is done., continuous Green /yellow means success, red means failure.
    Nizar Ghosn likes this.
  7. snerd
    Oklahoma
    Yes, what yours did is what mine did. Exactly. 22 minutes to upgrade, both birds.
    Nizar Ghosn and Buckaye like this.
  8. dataway
    Southern California
    Same here 22 minutes to upgrade
  9. blade strike
    Big Bear, CA
    You can also look at the front LED on the Gimbal if you're ever unsure..
    Flashing Green/Red = Update in Progress
    Solid Red = Failed
    Solid Green = Completed Successfully (after time led may go off) ...
    I like the tones.. Da.Da.Da (upgrading) Da...Da.Da. Complete. Long DAAAAAAAAAAAAAA Error in upgrading
    jryser, mmee1992 and skyhighdiver like this.
  10. skyhighdiver
    South Dakota
    No it will go limp at about 6-8 minutes as well as all the lights will go off for a while but they will come back on took me 18 minutes and another 5 to do 4 batteries its done when you get d-dd d-dd if its ddddddd its still working
  11. dedstik
    Mine took 22 minutes.
    :harry
  12. AirborneInPDX
    Portland, Oregon (USA)
    Mine was done in less than 20.
  13. Justgregg
    Denver Colorado
    I downloaded the bin file extracted to the root directory put the card in but no beeping and I don't see any lights on my gamble.
  14. Justgregg
    Denver Colorado
    Dah ...had a bald moment...files not in root directory. Now I'm getting beeping and alternating red green kites on gamble...think I'll have a shot now while I'm waiting
  15. Axidrain
    about 20 mins.
  16. Nizar Ghosn
    Lebanon
    ...22 mins and the RC took about 4 mins ... cheers
Similar Threads - Long did phantom Forum Date
How long did it take you to study for the 107? Rules and Regulations Jan 10, 2017
Didn't take long . . . General Discussion May 16, 2016
Paintball action I did on the long weekend Photos and Video May 3, 2016
Why did RTH take so long to kick in? Pro/Adv Discussion Mar 13, 2016
First long range, Didnt go as expected. Standard Jan 27, 2016
