How far have you dared fly?
Discussion in 'Phantom 2 Discussion' started by davlow06, Jul 16, 2015.
  1. davlow06
    I have just recently bought a used Phantom 2 that came with a GoPro 3+ for a pretty good deal. I have been flying it and recording video and photos, but am afraid of testing it's limits. How far has anyone here tested theirs and have you ever lost it?
    This may sound dumb, but I had thought about attaching a fishing line (on a rod of course), and going to a very large open field and just sending it out as far as possible to see when I lose control. I wonder if a line would hold it in place until I move in to catch up to it and bring it back. The line would just be to keep it from going further once the connection breaks loose. I have the DJI AVL58 FPV System already on it and can see how far away it is, but thought it would be a nice safety feature just to test it once. I have read about so many fly aways and with what I have invested in the equipment, would really, REALLY, hate to lose it.
    Thanks in advance.
  2. Scarecrow
    I'm impressed by the guys who put all their faith in their FPV systems and fly using it. Personally I'm not happy if I can't see my drone clearly enough to see which way it is going when I provide some stick input. But that's probably just me.
    Phil Sutphin likes this.
  3. jason
    Commerce Twp,MI
    Those days of how far and how high can I go are soon going to come to an end some time in September of this year. The guidelines that the FAA whats you fly are set at no higher then 400' and no further than 1500' an within VLOS.
    +1 I'm with you on that.
  4. landmannnn
    Coventry and Limoges
    It sounds dumb, you are more likely to get the line snagged and crash than anything else.
    My advice is to build up your confidence by flying in wide open spaces, it really doesn't matter if you don't push the boundaries. If you think about it, we all know people who test the top speed and 0 to 60 times of their new car, it doesn't make you less of a person if you drive within the speed limits.
  5. davlow06
    I'm fine flying within a safety zone and I'm not all about getting it so high or far away that I can't see it. I just want to get a good idea without losing it. I'm not planning on being a daredevil or flying against FAA regulations, but there have been times I was recording something and thought I could get a little bit closer to it with the P2 and was afraid of getting out of range.
  6. jason
    Commerce Twp,MI
    If it's worth filming then instead of getting quad closer why not move yourself closer within reason if possible.
  7. davlow06
    That's exactly the problem. I couldn't get closer.
  8. jason
    Commerce Twp,MI
    Flying out to 1500' isn't a problem where the problems lie is in depth perception and being able to see it at those distances. As long as you are not under something you could use failsafe and take over when it is close or when it's view once again.
  9. jason
    Commerce Twp,MI
    Who are you kidding that it isn't dangerous. A bullet shot up to the air which weighs far less then a quad can and has killed and injured people on the ground. So what makes you think your craft is any different then the bullet shot into the air. Is it because you can see with FPV what it is about to hit.
  10. Duke
    SW Lower Michigan
    I second that vote, Being a past Pilot and Airplane owner, (haven't flown in 20 years) I would hate to return to the sky's. Being a newbie Quad owner It scares the living **** outa me to watch these YouTube Vids with guys launching these things over 4K agl. There is absolutely no need for it IMHO.
    Those guys need to go see the wIzArD of Ozz and get a brain. o_O
  11. Duke
    SW Lower Michigan
    ANNOUNCEMENT! To all Jet Aircraft and Airplane Pilot's Commercial or Pleasure. You are no longer allowed to fly over Oceans and Mountains up to 5 KM which is 16404.2 ft agl. Drones now have the right of way. If you hit a Drone and it causes your Aircraft to crash and you kill yourself, crew, and passengers ITS YOUR FAULT!
    #11 Duke, Jul 17, 2015
  12. jason
    Commerce Twp,MI
    Don't try to justify your actions as safe because you have no idea what is or isn't below you when and if you were to loose power.
  13. Duke
    SW Lower Michigan
    You obviously don't get the point! There are many Airports that are right next to oceans and in the mountains. Besides you were talking 5km. why switch and lower criteria to 30meters! But yes some airports even use the beach as a runway next to ocean. You may find this Video Interesting.
  14. jason
    Commerce Twp,MI
    I don't see an analogy in your statement. Jet aircraft are manned while quadcopters are not. You still cannot justify your position that flying 5km isn't dangerous and reckless.
  15. Phil Sutphin
    Get yourself an iOSD-Mini, a 5 GHz Tx/Rx setup for FPV (including a display etc...) and you can see how far you are, how high you are, how much battery life you have and a couple of other tidbits of useful information. Not to mention you can frame your shot by seeing live what your GoPro is pointed at.
    I cannot imagine flying without all of that information at my fingertips and the cost is relatively cheap (less than $200'ish).
    Good luck flying!
    Duke likes this.
  16. Duke
    SW Lower Michigan
    Very nice footage Phil ;) And I agree I have all of the above and wouldn't fly without it!
  17. Phil Sutphin
    Thanks Duke, that was only the 2nd time I had it up and with no CP filter for the camera, the colors aren't that great, but that is on the way!
  18. jason
    Commerce Twp,MI
    I have one extra piece of equipment attached to the monitor and that's a DVR to record all the telemetry.
  19. Phil Sutphin
    Nice!
Similar Threads - far dared fly Forum Date
Transient by Dustin Farrell Photos and Video Dec 22, 2017
Farming Videos/Drone Videos Photos and Video Dec 9, 2017
How far can a standard fly and return home? Standard Dec 4, 2017
How far can you fly phantom 3 standard? (Late 2017!) General Discussion Nov 24, 2017
SAFARI LODGE at Jungle Cat World Photos and Video Nov 16, 2017
