atoms said:Just ordered a Phantom 2 with gimbal for my GoPro...
Just wondering if these things are pretty reliable in GPS mode (probably the only mode I'll ever fly in since my area is almost always somewhat windy)
LeoS said:My brother claimed he experienced loss of control just yesterday with his Phantom 2 (w/ zenmuse, gopro, fatshark 250mw vtx, flytex, iosd mk II). He was passing one of his neighbor's house when the craft zig and zagged with no input from him, but curiously he could cut the throttle to land on the neighbor's roof.
I've yet to 'interrogate' him but I do notice that when I fly in that area with my P2V around that area in the past, my wifi connection always got cut off near that exact same spot. Even when I've put on the 14dbi TP Link antenna. So I think his story was plausible that it wasn't user error (other than the bad area choice).
Oh yeah, I've also seen my PV's controller being a HUGE interference for his Fatshark's VTX. Anytime I turn on my tx, his fatshark goggle get scrambled, even as far as 5m away. We've yet to try changing the fat shark's channel to avoid this interference.
thongbong said:Thats good to hear! On a true flyaway he would have not been able to cut the throttle at all. Probably outside interference like you said. But funny he landed on neighbor's roof :lol:
LeoS said:Oh yeah, I've also seen my PV's controller being a HUGE interference for his Fatshark's VTX. Anytime I turn on my tx, his fatshark goggle get scrambled, even as far as 5m away. We've yet to try changing the fat shark's channel to avoid this interference.
LeoS said:Yeah, I'll see what I can find out the next time we fly together. It also make me question whether the default Phantom (v1.1+ and Phantom 2)'s receiver make use of Futaba's FASST algorithm or not. It should significantly reduce these occurrences. Now, if I can get him to repeat the incident, then we can get a baseline to compare with, before he upgrades his tx\rx to original Futaba's :mrgreen:
ianwood said:I was thinking about this earlier. P2V and P2 are kind of incompatible but maybe it's just the analog FPV that suffers as it has no way to cope with interference. Good to see the P2V can work around the P2 analog FPV signal and vice versa.
ianwood said:This would be really interesting to explore. You have a known trouble spot. Would be great to see how the Futaba TX/RX compares to Futaba TX/stock RX and stock TX/RX. It would also be interesting to find out what it is. Maybe your brother's neighbor is running some home brew WiFi gear or he's got an old microwave that he's constantly cooking burritos in! Actually, you should find out what it is first to make sure it is on when you do your testing.
LeoS said:I just saw his video, it's not the same spot as my trouble spot (about 150m away); so I don't think we've found a proper test case yet. I can imagine you can simulate the interference by using wifi access point with panel antenna, bursting ip traffic through it, aiming the antenna at a hovering phantom. Then switch the AP's channel from 1 to 13 while repeating the test =P
