How Accurate it auto takeoff and RTH ?
Discussion in 'Pro/Adv Discussion' started by cassalatico, Mar 6, 2016.
  1. cassalatico
    As the title goes, I have found a really good flying area close to my home the problem is that the field is fenced off with barbed wire. I would be taking off from a pathway on this side of the fence then flying over the other. As I'm a beginner let's say there was zero wind and I auto takeoff how much could the craft possibly move left or right ? And again on RTH and auto land would it be accurate enough to avoid the fence and land close to the path set as my home point? Thanks
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I would plan for at least a 20 foot difference -- just in case. From my experience, I found it usually lands within 10 feet of the home point.
  3. flpholt
    palm harbor florida
    wouldn't chance it sounds like a disaster waiting to happen
  4. cassalatico
    And what would takeoff tolerances be in terms of auto takeoff accuracy
  5. Dirty Bird
    Glen Burnie, MD - USA
    Mine normally does an RTH within a 20' diameter circle around the Home Point. I don't really use auto-takeoff but when I lift off manually she usually hovers within just 2--3'. You should be right there with the controller in your hand in case manual intervention is required on takeoff or landing.
    #5 Dirty Bird, Mar 6, 2016
  6. AirSpace2016
    I use auto take off quite frequently. I find if there is wind it will drift slightly enough that I counter the wind and then its fine. If there is no wind then it just hovers
  7. flpholt
    palm harbor florida
    always use auto take off never have did it manually from the start it works great
  8. With The Birds
    Australia
    Your RTH accuracy is as good as the horizontal positional accuracy spec quoted by DJI. Not good enough to be safe in most curcumstances.
    On the occasions i have relied on RTH i have cancelled out as soon as i regained control of the aircraft. I experimented with letting it get close to landing once and was suorised how far of the mark it was, would have dipped the camera in wet sand and salt water if i let it complete.
    Auto take off is actally more effort than a csc followed by throttling up and you need to take your eyes iff the aircraft to play with the app.
    Why do you need to take off right next to the fence?
  9. artichoke
    I'd try in a more open area five times and see how accurate it is. I read in another thread that the accuracy depends on whether your tablet itself has GPS capability.
    My tablet is an old Ipad 4 (not mini) for which I have an extender on the holder. It doesn't have GPS capability and so my RTH radius is more than it would be with a newer tablet or phone, so I have to account for that.
Similar Threads - Accurate auto takeoff Forum Date
Is DJI's geo map webpage restricted zones accurate with what is implemented in aircraft firmware? Phantom 4 Discussion Dec 26, 2017
No Accurate Airspace Maps for Drones Other Than Skyward? General Discussion Oct 20, 2017
Find my phantom2+ How accurate Phantom 2 Vision + Help Jul 9, 2017
Wrong/inaccurate NFZ - cannot take off - what to do? Phantom 4 Discussion Jul 9, 2017
Alltitude not accurate Phantom 4 Help Jun 4, 2017
