Mandrake said:
Reset home position by moving switch 1 ( NOT the GPS one.) 5 or 6 times between top position and middle position only don't go into Home Lock position while doing this. The led will blink green rapidly when locked .Mandrake.
This is wrong, you can reset course lock by toggling S2 five times - as quickly as you can - between top and middle.
Reset Home position by toggling either from top to bottom or (easier) from middle to bottom - five times again.
If the reset is successful you will see a rapid green flashing from the LED
Note you can reset home in the air and it will log the new altitude should you initiate the return to home either deliberate or a s result of losing control signal.
This is useful if you know the terrain or trees are likely to mean the preset return height of 20 metres is not adequate ground clearance.
