Home Lock - reference point?
Discussion in 'General Discussion' started by docramage, Feb 1, 2015.
  1. docramage
    When in Home Lock mode, does the software regard your Home Point as the reference, or the physical location of your Remote Control?
    In other words, is it using GPS to fly to a remembered location, or signal strength from the Tx?
    Philip
  2. Narrator
    Melbourne, Australia
    Welcome to the group!
    It's using the GPS and IMS to remember your home point, not your RC.
  3. Happyflyer
    Cold, Cold, Michigan
    +1
    ....And another welcome to the best Phantom information forum you can find.
  4. Monte55
    Raymore Missouri
    I have seen some ask the homelock question. They were under the impression that the quad will come back to them. If they have moved a distance while flying and went to home lock, the quad will go to the home position it recorded at power up and not to where they are standing now unless they reset home lock at their new position. This could be confusing to someone not getting this and wonder why the quad is going somewhere else
  5. BWJ
    BWJ
    Denmark
    bob bob ;)
  6. Happyflyer
    What about that change in the program that Home Lock changes as you move the receiver to a new location? Or did that update go away?
  7. aartsf
    You are right, there is that extra feature called dynamic home point that can be enabled in the dji app. Nontheless Monte is right by saying the basic setting is that Homepoint is set at the location of the bird when it is started up and has a locked sufficient satelates.
    Fore newbies it is wise to stick with the basic homepoint setting for a while. Later on they can start experimenting with dynamic homepoint or even, as a third possibility, manual homepoint (re)setting for that matter.
    Just an opinion.
  8. Monte55
    Raymore Missouri
    I didn't see any info on which Phantom he has so I went with the basic no frills answer.
  9. aartsf
  10. Narrator
    Dynamic home point? OMG... just another thing that can go wrong... lol
  11. Mako79
    Sydney Australia
    I love it and cannot fly without it. I ditched my p2 ver2 because it didnt have this feature.
    Just make sure the ring around the radar is green. Its an awesome feature knowing that you can walk/run/ride/drive/boat and know that thephantom will return to you.
    If you know what you're doing, the phantom can go in follow me mode
  12. kirk2579
    Girard. ohio
    I don't know what I am doing! lol
    can you elaborate on the follow me mode please?
  13. Mako79
    Sydney Australia
    Enable NAZA and check the IOC box in the Phantom Assist software (MAC/PC). This will enable CL and HL flight modes.
    Enable the DHP on your DJI app.
    Turn on locations/GPS on your device.
    Optional: Have Ground station enabled and maps downloaded.
    You will notice on your DJI app > Radar ring = yellow/orange. This means DHP is on but NOT locked.
    Be patient and it will lock onto your device. If it does not, swipe to ground station and see if you are in reference to your phantom. The ring around the radar should turn green = DHP is on and LOCKED to your device. It will now attempt to ping you every 2 seconds. You can see this happening in the ground station.
    For the follow me to work, the phantom MUST be greater than 10 meters radius from you, otherwise it will switch to course lock direction. Flick on Home lock and pull the stick back gently. Provided it is > 10m from you and the GPS from your phone is updating the phantom then you are good. With a bit of skill you can just pull the stick back gently and pan to get nice a follow on a boat.
    On a side note, if you trigger RTH/failsafe and still moving, it will land at the point you triggered the RTH/failsafe. So if you are on a moving boat, it will land in the water =(.
  14. KMW
    KMW
    Is DHP only a thing on the P2? I don't remember seeing that in the Assistant when we updated firmware.
  15. aartsf
    DHP works with any phantom with a NAZA-flightcontroller and a wifi-connection with the latest dji-app that also has ground station. It is in this dji-app DHP can be enabled and disabled.
  16. Meta4
    Meta4 Moderator
    Staff Member
    So that's any P2V or P2V+ - anything running the DJI app on a GPS enabled phone or tablet.
    Not for the non-Vision P2s
  17. jason
    Commerce Twp,MI
    He did mention it at the very bottom of the page that he had a P2 V2. "Rc Heli: Raptor, Freya, TRex, Gaui etc - all elegantly crashed . . . and now Phantom 2 (2015 model - not Vision)".
Similar Threads - Home Lock reference Forum Date
Home point lock General Discussion Jul 18, 2017
Advanced Home lock wont work Phantom 3 Help Jul 13, 2017
Home lock not working General Discussion Jun 25, 2017
Cant get into Intelligent Flight mode: and Course and lock home lock General Discussion Jun 4, 2017
Standard Home lock Phantom 3 Help May 30, 2017
