craft will not maintain altitude when i initiate and kind of descent the craft will not hover. i can adjust the descent with the throttle up but if i let go of the controller the craft will descent at a slow but dangerous fall out of the sky. and suggestions.i have recalibrated with the naza program. mind you the i just to the unit this month off of ebay
You need to calibrate both the IMU with the unit level and then the remote. After that you should see a big improvement. Use the assistant plugged into the PC. Check you tube video to see what and how if you need to.
