High pitch noise coming from the phantom
Discussion in 'Phantom 2 Discussion' started by RafaelS, Jan 25, 2016.
  1. RafaelS
    San Francisco
    hello folks, I'm not sure if it's been covered before but when I fly my phantom 2v2 I hear some kind of high pitch noise coming from the phantom, is not super loud but I can hear it. The bird flys just perfect but I'm not sure if the noise is normal or i should be looking for something wrong. Please advice and thanks in advance.
  2. Stathis
    Hello RafaelS! I also have a phantom 2v2.Try this.....Start the motors without props and then stop them.Check if all the motors stop together, If not maybe there is a problem with a motor. Turn the motors with your hand and check if all the motors turn free and there is not something blocking them.Also check that your props have no damages.
    Mako79 likes this.
  3. RafaelS
    San Francisco
    Hello, so I checked everything you told me to and everything seems to be working just fine, as I posted before the quad flys just normal it's just that notice that I don't know where is coming from. Could it be the gimbal making interference?
  4. jason
    Commerce Twp,MI
    You may have a bad bearing in one of the motors. With the props on see if there is any lateral movement any movement in the bearings or the bearing may be seated and is spinning causing the noise. Then pull up on all of them to see if the C clips are connected.
    I have a motor on my desk where both bearings are not seated and there was lateral movement. Either both bearing were not the correct size or the motor seats were not to specs causing the bearings to spin.
    iowahill likes this.
  5. RafaelS
    San Francisco
    No lateral movement at all, I turn on the quad with one prop at the time and I don't hear any weird noise at all. Would it be dangerous to just keep on flying it like that since I really don't know what the issue is?
  6. jason
    Commerce Twp,MI
    That's up to you.
  7. LetsGetStarted
    Brisbane, Australia
    I think thats normal. Mines always made some high pitched whining sound. I think its because the motors are burshless? Maybe?
  8. RafaelS
    San Francisco
    It could be, as mine flys just perfect but to be honest with you I never noticed it till couple weeks ago. Maybe coz I don't fly it as much since I got my phantom 3 so I want to sell the phantom 2 but I just want to make sure it's in really good shape before it goes
  9. 750r
    Pa, USA
    Can you put up a short vid ?
  10. RafaelS
    San Francisco
    Video quality is horrible I don't know why it came up like that but at least you get the idea haha
  11. 750r
    Pa, USA
    To be honest she sounds like my P2 the only thing I seen was a little glitch with the gimbal .
  12. RafaelS
    San Francisco
    It's good news I guess and yeah gimbal is kinda acting up, if I reset it do you think it'll solve the issue?
  13. Bob Mador
    Crete, Greece
    I've been meaning to ask about the high-pitched whine on my P2. I've heard it from day one. I'm hoping it's just a normal noise and doesn't indicate impending failure!
  14. iowahill
    Roseville, CA
    I'd lean toward a bad bearing too. If the pitch changes with throttle input, you've pretty much confirmed it. Take the props off and bench-test it.
  15. N017RW
    Palm Beach Co.- FL
    Mine's done it since I got it in May '14.
    No bad bearings, all motors original, similar in operating temp., flight times ~20 min.
  16. LetsGetStarted
    Brisbane, Australia
    IrixGuys phantom 3 does it too!! Listen really closely at 16:16 (16 minutes and 16 seconds) Into the video.
    You can hear a little high pitch squeal at times while he is hovering his quad
  17. RafaelS
    San Francisco
    So I guess we're good then :cool:
    #17 RafaelS, Jan 29, 2016
  18. LetsGetStarted
    Brisbane, Australia
    Yep!!! Mine does it too at times. I thought it was a problem as well when i heard it but its never failed me so, i say its normal.
  19. jm/lh
    Just wondering... how many of you lubricate the motor bearings?
  20. N017RW
    Palm Beach Co.- FL
    Never.
    They're sealed.
    Adding lube is only superficial and just retains foreign material.
    I got out of nitro models to get away from the oily grime.
Similar Threads - High pitch noise Forum Date
High Pitch Noise DJI Phantom 3 Standard Pro/Adv Discussion Dec 25, 2017
High pitched noise from my DJI charger Phantom 4 Pro Discussion Nov 18, 2017
High pitch noise General Discussion Sep 16, 2017
High pitched noise from P4P Phantom 4 Discussion Dec 3, 2016
High Pitch Motor Noise Pro/Adv Discussion May 7, 2016
