Alright,
Here is my story.
I screwed up, crashed my drone - P3S. Only thing that broke on it was the Gimbal. (Yaw arm, motor attached to that arm, ribbon cable, and the vib board)
Anyway, i was upset. I still wanted to see if it would fly, so i flew it with the camera snapped off at the yaw arm. it flew just fine. I decided I would lighten the aircraft up a bit but removing the base of the Gimbal, where the grey and black antenna wires are and the grey ribbon cable.
I flew it like that perfectly for about 10 minutes, i did notice the lights were flashing strange, but it flew, hovered etc with no issues, note i did not have my phone connected.
Once I landed, shut down the motors, it would not start back up.
I tried again this morning, still wont start. The phone reads no battery life or anything, so I connected that main gimbal board again. I now see battery life etc. Aircraft still will not start. Blinks Yellow lights, then occasionally will blink slow green for a few seconds, then yellow again.
I tried updating firmware, it downloads but will not install, says fail. Is this because the SD card that is in the camera needs to be installed? I see how to install firmware via card on the adv/pro but my gimbal has no spot to insert an SD card. Is this why the update is failing? Or how do I get my controller to get signal again.
Overall health i have a bunch of errors etc, yaw error pitch error etc, does that effect anything?
Any help at all would be much appreciated.
Thank you guys!
Here is my story.
Thank you guys!
