News to me....mine is still in the box-as I got the Zen and never checked it out.CunningStuntFlyer said:havasuphoto said:Not true. In fact, it will only work with the Go Pro 3, or 3+CyberVet65 said:I was just informed that the camera mount on the P1 is sized for the GoPro Hero2? True?
IF, you want to use a GP1 or 2, you can still use part of the mount, and just attach your 1 or 2 in it's original case, upside down, and put the silver screw threw the hole on the bottom of the case.
You're mistaken.
The stock camera mount (frame) that is included with the P1 is designed around the GP2.
Here's the original OEM mount: http://quadcopters.co.uk/dji-phantom-go ... -631-p.asp
Folks can either add some thin foam to make it work with the GP3 or just use their GP3 case (waterproof, skeleton, or frame)
I'm "fishing"......so far, you've taken the bate on ever one of my "errors".....CunningStuntFlyer said:havasuphoto said:News to me....mine is still in the box-as I got the Zen and never checked it out.
Then why comment if you have no experience let alone knowledge?
