help
Discussion in 'Phantom 2 Vision + Discussion' started by MFEDDS, May 30, 2014.
  1. MFEDDS
    How can i extend the range of my phantom 2 vision plus i am only getting 1000 ft away and i lose signal? thanks for you help.
  2. kgarrison
    Do you have it set to FCC mode?
  3. Mori55
    NJ-USA
    Do you have the range extender folded out pointing at it ?
  4. nhoover
    Los Gatos, California
    How much wifi interference do you have where you fly? What's the humidity level?
  5. D_Tshudy
    Philly
    Be sure that the tip of the control antenna is pointing up, not pointing at the phantom. As others have said earlier, the flat top of the WiFi extender should be pointing at the phantom.
  6. MFEDDS
    When i turn on my radio it beeps 2x which what i have read it is in fcc mode. Yes I have the extender pointing at it and the control antenna straight up.No humidity. Thanks for the help.
  7. Jeremyconk
    Download the Vision Booster App..... I live in a very active urban area... It almost doubled my FPV range.... Best app ever !
  8. Mori55
    NJ-USA
    Someone had that problem and one of the wifi antennas was unplugged in the extender.
  9. nhoover
    Which are you losing, Control or FPV? There are two separate radios. Both should work much further than 1000' in good conditions. What is the message you see on the screen? "Control Signal Lost" means you lost control (5.8Ghz). I've had this work to >7400' in good conditions (9500' on the P2V). On the other hand if the error says "Phantom Connection Broken" your 2.4Ghz FPV connection is gone. I've had this work to over 4000' (and over 7000' with the booster app mentioned above) but it depends on the preview quality setting you're using. I have used the highest setting 640x480@30 at over 3500' without the booster app. 1000' is more like the limit of the older P2V (non plus) system.
    Aiming with the 2.4Ghz antennas is important if you're flying out a ways. Point the flat part of the repeater right at the P2V+ as it's flying. You don't have to aim the 5.8 Ghz antenna as long as it is NOT pointing right at the P2V+. For instance if you were flying straight up and had the white antenna pointed straight up, that would be optimally bad. In that case point it parallel to the ground. For normal flying, far away and not super high, pointing it straight up is more like it.
  10. MFEDDS
    It said Phantom connection broken. I checked the extender and both antenna were plugged in. What preview settings should I be using?
  11. PhilAnderson
    Living In The Woods Of Beautiful Bonney Lake, WA
    This is my only complaint with my Vision+. I lose control signal at about 1,000 feet. Others seem to be getting much more, stock. To be clear, I still have FPV but lose control of the copter and it returns home. I suppose I could add some other antenna but it just seems like I should be getting more like others seem to do.
  12. Mori55
    NJ-USA
    Make sure your in FCC mode
  13. yawnalot29
    Here's how you do a positive post.
    I am able to get about 4900 ft max and 4000 ft on record (flytrex). No mods, just straight out of box.
    I did have to move the controller a bit to "aim" the signal (and adjusting the Wi-Fi extender accordingly as well). The omni directional (5.8Ghz) field does not seem uniform. I assume you know about the null point and avoid that.
  14. CRankin
    I know it's an obvious question, but.... are you maintaining line-of-sight to the Phantom? I ran into the same issues a couple weeks ago while putting some video together for a property. As best I could tell, that turned out to be a large part of my problem.
    If that still doesn't resolve your issues, there's a site (www.fpvlr.com) that sells antennae that will help you boost your signal. I know he's on the forums here, and might be able to reach out to you and help offer something to solve this issue.
Similar Threads - help Forum Date
Airspace Effective Hours - Help Me Understand Rules and Regulations Today at 11:20 AM
Standard map help please Phantom 3 Help Today at 6:18 AM
Help: better understanding of range vs channel availability General Discussion Yesterday at 1:37 PM
Professional Need easy help Phantom 3 Help Yesterday at 12:45 PM
4K editing help Video/Photo Editing Yesterday at 1:17 AM
