Help with batteries not charging!
Discussion in 'Phantom 2 Vision + Discussion' started by swankster988, Aug 31, 2014.
  1. swankster988
    I finally got around to opening the vision plus, however both batteries will not charge? I have tried unplugging turning on then off and no blinking charging status. I followed directions, am i missing something?
  2. iSander
    Belgium
    If the batteries are over 75% of battery life they will not charge.
  3. swankster988
    according to app they are at 38%
  4. Brammo
    Did you try pressing the power button once and then holding the power button in for 2 seconds (when it's plugged in to charge)?
  5. swankster988
    Yes with both batteries... It stays on but i get two solid green lights.. no flashing
  6. iSander
    Belgium
    That means that the battery is on, do the same thing again to turn it off
  7. 4wd
    4wd
    North York Moors
    If you are sure they are connecting properly, sounds like a bad charger.
    There should be a small LED on it - green or red?
    It's hard to do anything wrong, I find that flap thing rather fiddly though.
  8. swankster988
    on the charger when i plug it in it is a solid green... I am frustrated..
  9. swankster988
    Ok so.. I calibrated phantom, changed to naza modes connected everything, etc... turned it on and let it sit for 5 minutes turned everything off took battery out and plugged that one in, now i get 1 solid green with the second flashing. Does that mean its charging?
  10. swankster988
    Now it's not doing anything...No lights...
  11. 4wd
    4wd
    North York Moors
    It would take at least an hour to charge, so that sounds like a bad connection.
    Does wiggling it make it come on?
    That won't fix it though.
    Your dealer might exchange it, or you might just buy another they are not to pricey.
    I would probably do that and open the dud up, try to resolve it for a spare.
    Two chargers is handy anyway at times.
  12. Dirty Bird
    Glen Burnie, MD - USA
    The charger has its own light. When you plug the charger into the wall its power light will turn green. Plug in a battery and the charger light will change to red to indicate it is charging. The battery bars should illuminate to indicate the degree of charge and increase as the charge progresses. When the battery is full, the battery lights will turn off and the charger light will turn green. Since two separate batteries are suddenly not charging, then I suspect the charger has gone bad. If you have a friend with a Phantom 2 perhaps you could test this on his charger?
  13. swankster988
    the charger stays green when i plug battery in...
  14. swankster988
    Well guys, i played with cord and found the culprit, cable was kinked a little bit. I do have it working now but it is a bad charger, will call BH photo and have them replace it!
Similar Threads - Help batteries charging Forum Date
N00b Needs help charging LiPo batteries Phantom 1 Help Aug 20, 2015
Help reconditioning my batteries Phantom 2 Vision + Discussion Jun 8, 2016
Anyone need batteries? I'm willing to help out. Pro/Adv Discussion Jun 9, 2015
Newbie Help With Remote Batteries Phantom 2 Vision + Discussion Feb 16, 2015
Help to find good batteries FPV (First Person View) Jan 19, 2015
