Bresson said:
LeoS said:
I've not seen it yet, and it would help if you show what happens before-after the <2 brief seconds in that clip. (Looked intentional if one just watches the clip)
Btw, are you in HK?
Were you on a roof of a building on a hill? Looks pretty cool
http://youtu.be/Q6tY4TRVcss
Thanks LeoS,
Here is the clip including the before-after. It really 'looks' like intentional, but I swear I was scared to death at that moment. Luckily it holds back itself and I can land safely after that.
Yes I'm in HK. You too? Really hard to find some good place to fly.
I'm not in HK, though I sometime fly there
I don't know enough about the Phantom to make a good guess of what had happened... it seemed that it was a clear and still day (no winds?) and your movement was gentle enough just before the shake.
For some reason NAZA wanted to correct the tilt, then realised it over-corrected, then started to wobble back into level... I think the problem was in the initial quick tilt; what followed after was just the correction by the flight controller.
If you were doing holding the stick for a long time, there's a 'feature' of NAZA to try interrupt the movement to see whether it's responding to a radio interference or not. But that usually happens when you're flying straight and pushing the throttle forward for 10seconds+.
