Advanced HELP! PHANTOM 3 ADVANCED APPEARS AS PROFESSIONAL IN APP
Discussion in 'Phantom 3 Help' started by botstudioz, Dec 2, 2015.
  1. botstudioz
    Accra Ghana
    This is quite a serious issue for me. I have updated my firmware to the latest version for the P3 Advanced yet it still shows Professional when I connect.
    Screenshot showing my P3 Advanced Screenshot_2015-12-02-09-56-19.png For this reason, I have been unable to fly my drone. It flies perfectly fine but can't take videos as its all dark and won't even lock on to gps. By a stroke of luck it showed advanced when I first upgraded the firmware recently and all worked well but next day it went back to the previous issue. Note that this issue had started before I upgraded and I was only waiting for the new update. Now that I have upgraded and it's still in same state, I am confused because I have lost some work because of it. I had four successful flights in my country before this started! Please help.
  2. bbfpv
    Long Island, NY
    What have you tried?
  3. botstudioz
    Accra Ghana
    I have tried everything. Upgraded firmwares, deleted and reinstalled apps, used ios and apks. Used older version apps, etc. I have tried almost virtually everything.
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Do you still have the TXT file in the root of your memory card? If so, please post the contents here.
  5. botstudioz
    Accra Ghana
    I do have the text file for the last upgrade and will send it in here asap. My Laptop is down now since I saved it there. Before the day runs out I will put it on here. Thanks. I will be most grateful to have this fixed.
  6. hunch
    does you gimbal has a fan on top of it?
    it is possible that you actually have a 4k camera installed, which would cause the app to display Pro vs. Advanced.
    the only difference between P3A and P3P is the gimbal. everything else is identical. well besides the silver and gold stickers :)
  7. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Wouldn't the app only think you have a Pro if you installed the Pro firmware?
  8. hunch
    no, if you put gimbal from advanced on a P3P bird the app will think it is P3A bird and vice versa. gimbal is the only difference.
    that's why some people that have P3A bird just upgrade the gimbal and voila now you have a P3P bird.
  9. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Interesting. Have you ever tried swapping the camera without installing the proper firmware?
  10. hunch
    yes. it does what i just explained.
  11. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Have you ever tried installing P3P firmware on a P3A (with a P3A camera) to see if the same occurred? (I was wondering if that's what the OP did.)
  12. hunch
    no i did not. why would i want to do that? :)
    and yes i am thinking the same thing. he probably did exactly that.
  13. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I figured you were into experimenting :)
  14. hunch
    well yeah, but installing P3P FW on P3A gimbal is just asking for trouble. ;)
  15. botstudioz
    Accra Ghana
    No I don't have a second Camera to swap it with. But I actually put the P3 Advanced firmware not the Professional. And there is no fan ok my gimbal. I even took out the holders and connectors then reconnected the gimbal, same issue occured. This is so frustrating as it is limiting my shoot. Like I said it's all upgraded.
  16. snerd
    Oklahoma
    At that screen, I can click the bird type to choose any of them.
    Sent from my iPhone 6+ using Tapatalk Pro
  17. botstudioz
    Accra Ghana
    On what screen please and app. Send the link for the app please
  18. snerd
    Oklahoma
    Where it says Phantom 3 Professional, I have a blue tick mark next to it. I choose my model after touching the model name.
    Ken Hanks and bobmyers like this.
  19. snerd
    Oklahoma
  20. bobmyers
    San Antonio, TX
    Another one for the snerd:D
    [​IMG]
Similar Threads - HELP PHANTOM ADVANCED Forum Date
Help! Another Phantom 3 Advanced Issues??? Pro/Adv Discussion Oct 28, 2017
Help! Lost Phantom 3 Advanced Pro/Adv Discussion Mar 27, 2017
PHANTOM ADVANCED OWNER FROM UK (NEED HELP/ADVICE) Pro/Adv Discussion Mar 17, 2017
Need Help! - Litchi 3.9.2 on Phantom 3 Advanced w/Older Firmware Control (Go, Litchi, etc..) Dec 14, 2016
P3 Firmware Need Help! - Litchi 3.9.2 on Phantom 3 Advanced Firmware Dec 12, 2016
