Help outer battery shell needed for p3
Discussion in 'Pro/Adv Discussion' started by Wez, Sep 29, 2016.
  1. Wez
    Wez
    hi folks
    I have an issue dropped the battery on my p3 advanced Oops
    Battery inside is fine and worth saving
    But outer white she'll is cracked to bits
    So long shot does any one have a dead / non genuine battery that I could have / purchase
    Just for the outer shell
    Pretty please
    Am based in uk
  2. Harry650
    Gloucestershire UK
    I have a once used non genuine batt but at £40 feel it is too expensive for you to cannibalise.
  3. Wez
    Wez
    Thanks for replying
    And yes is a bit much
    Are u still using the fake battery ?? And if so what firmware version are u on
  4. Harry650
    Gloucestershire UK
    I only used it once then updated fw to 1 5 7 and it wont take off.
  5. alokbhargava
    San Francisco, CA
    I don't think its worth using a cracked shell battery as you really don't know what all has gone bad with it.
    ROD PAINTER likes this.
  6. Wez
    Wez
    Ok so it's a paper weight now :)
    If u decide to sell it cheaper let me know
  7. Wez
    Wez
    Fair point but it's £120 and says it was all fine when in drone but just unsure about cracks to casing and the security when flying as basically broke of the front bit
    I have already removed the cells ect from the plastic case and all looks good
    Just seems a waste otherwise
  8. alokbhargava
    San Francisco, CA
    You are the best judge for the current state of the battery and yes batteries are expensive. If choice is given to me, I won't play with risk of fire. I will skip two - three dinners outside and buy a new battery for $80-100. Let me admit I don't have guts like that you have.
  9. Wez
    Wez
    Don't get me wrong I will use this as an excuse to buy some more :)
    Just wanted to know if I could do it and succeed
    SAFETY NOTE to anyone thinking of taking apart a phantom battery
    If u hit one of the cells/ battery inside it will very very likely burst in to flames or blow up in your face !!!!!
Similar Threads - Help outer battery Forum Date
Broken Outer Antenna Stick in Controller in Phantom 3 Standard- HELP and GUIDE ME THRU Standard/4k Discussion Dec 14, 2015
Phantom 3 standard no SSID help Standard/4k Discussion Today at 9:33 AM
Professional Help with new camera/gimbal rig Phantom 3 Help Today at 12:52 AM
Standard help Phantom 3 Help Yesterday at 10:43 PM
Gimbal off-center, need help Phantom 4 Help Yesterday at 12:05 PM
