Help Needed- Motors will not start after Upgrade
Discussion in 'Phantom 2 Vision + Discussion' started by decoy86, Sep 20, 2015.
  1. decoy86
    Well I cant figure I out.
    Phantom V 2 +
    Upgraded to latest firmware for Copter and RC- I cannot get the motors to turn on. I has no problem locating satellites - up to 12-
    I have turned off the Firewall- No luck
    Reset the RC with the copter- No luck
    Running Windows 7 on the PC..
    Made sure RC was in Mode 2-
    IMU cal completed- Basic and advanced- No luck
  2. jason
    Commerce Twp,MI
    There are two things that come to mine that will keep the motors from spinning up are.
    1) GPS plug is not setted in the socket.
    2) The info pins which are spring loaded below the battery terminals are not making contact with the
    battery.
  3. RoyVa
    Virginia
    It's possible the upgrade corrupted. I would download the software again and re do the upgrade and see if that fixes the issue. Can't hurt to try. After any major upgrade alway good the calibrate the IMU, RC and compass again
  4. RoyVa
    Virginia
    If your IMU is failing the calibration be sure the quad has been off for a while and the unit is cool. Sitting idle with the power on causes it to heat up internally and you will get a failure or won't calibrate. Remember quad must be level to get good results.
  5. robsquad
    Wolverhampton, UK
    calibrate r/c and bird to make sure sticks get full travel
  6. BlackTracer
    Winter Park, FL USA
    +1. Make sure you calibrate the sticks first in the RC assistant, then again in the PC assistant. I bet it works after that.
    robsquad likes this.
  7. RoyVa
    Virginia
    Did you get it Decoy?
Similar Threads - Help Needed Motors Forum Date
phantom fc40 help needed please ? Phantom FC40 Help Thursday at 2:07 PM
Help needed on Pro+ Editor feature. Phantom 4 Pro Help Thursday at 12:27 PM
P3 Standard, 65 ft Crash"""" Help Needed Standard/4k Discussion Aug 4, 2017
Help needed please General Discussion Jul 28, 2017
Schematics help needed: Esc1000 input decoupling capacitor Phantom 4 Pro Discussion Jul 23, 2017
