Help me with software
Zimmerman Mn
My P2 has been idle for a couple years. Now that I have working batteries again, please help me remember all the updates I need. Does the vision assistant version 3.8 include the main centrall board firmware and main controller firmware? Any certain order or update procedure?
The 3.8 version is the newest version, it should have everything you need. One thing that's very important make sure you're on a level surface away from any magnetic fields. To update you just need to plug into the 3.8 vision assistant software and go to the Upgrades tab, it will tell you what needs to be upgraded. I don't think it matters in which order. I usually start from the top and go down with upgrades. You might want to do an advanced IMU calibration as well. If it's floating in One Direction or the other this will usually solve that problem. If you're not sure check out some of the YouTube videos. They usually have some good information. Good luck.
