help me buy the right drone
Discussion in 'Pro/Adv Discussion' started by Airborne 2500, Apr 13, 2016.
  1. Airborne 2500
    Is the phantom 3 advanced, or phantom 3 professional the drone for me? I am looking to be able to travel up to 1mile away, have clear video feed, and to attach a drop & release mechanism that can carry a payload of 1.5-2lbs. If not, what do I need to do this. Bigtex2500@gmail.com
  2. force recon
    What you dropping off..or should I say where you dropping off.....humm
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I don't think a Phantom will handle this well.
  4. m0j0
    Not a phantom of any line.
  5. DroneDestination
    Yeah, seems like you need some sort of custom build.
  6. henick
    The vagueness makes it sound like a coke run. Not a good spot to ask that.
    libertyflyer likes this.
  7. CafeRacer
    Flying over the wall to Mexico, picking something up and flying back. I wonder if the Cartel has done this yet?
  8. Airborne 2500
    Calm down everyone only waterballoon fighting
  9. alokbhargava
    San Francisco, CA
    In reality P3 is not designed to carry a load, landing gear is too weak and there is not place below the P3 to accommodate large volume below the shell. Also there is no dropping mechanism.
  10. ddh1313
    The standard might be the best option within the phantom line I think. It has slightly more flight time and roughly the range you are looking for.
  11. msinger
    Approved Vendor
    Harrisburg, PA (US)
    You might be able to lift it with an Inspire 1. I also came across this 3D printed device that can be used to drop things by simply raising the landing gear:
  12. Ghost Rider
    I'd get a Standard to do coke runs. That way if it gets shot down, you aren't out as much. Definitely don't go with an Inspire. The Standard is slightly lighter and flies for about 25 minutes. I have not tested both to see which one flies longer but I'm pretty sure the Standard does. Although, I would be a little leery of going a mile with it. Good luck.
  13. ddh1313
    I'm not sure if we are allowed to link to YouTube but here's one of a P3 lifting 800+ grams.
    I have tried to lift 2 stock batteries 730grams with similar performance characteristics.
  14. Ghost Rider
    That didn't seem to go too well. That bucket was swinging all over the place.
    The Phantom is not designed to add weight. So any type of load carrying is gonna put you on the edge of disaster. Could burn up the motors. I don't know how the battery reacts but obviously it would eat into the flight time. My advice is, use the Phantom for filming unless you have FU money and just want to **** around.
    Procharged97 likes this.
  15. Procharged97
    Canterbury, CT
    My P3S goes over a mile no problem
  16. Meta4
    Meta4 Moderator
    Staff Member
    That weight would kill flight time and handling.
    Definitely not a task for a Phantom
  17. DroneDestination
    Lol
Similar Threads - help buy right Forum Date
Buying Phantom 4? (Newbie plz help) Phantom 4 Discussion Yesterday at 12:28 AM
Need a little help with what to buy. General Discussion Feb 12, 2017
Buying boosters to DBS (help needed) Standard/4k Discussion Feb 1, 2017
*Help please* Buying a new iMac to edit P4P 4k 60fps Phantom 4 Pro Help Jan 2, 2017
Standard need help to buy spare part Phantom 3 Help Dec 29, 2016
