Help connecting Ground Station
Discussion in 'DJI Ground Station' started by ActionChopper, May 9, 2014.
  1. ActionChopper
    Help please! I bought the DJI 2.4G Data Link system for my Phantom1.1.1 with Naza V2. It came with a BTU, CAN HUB, IOSD and of course the DATA LINK TX & RX. I was told that I would NOT need a PMU but now that I un boxed the system and tried to connect it, looks as though I will need a Naza PMU-V2. Is this correct? I just ordered the PMU today just incase. The data link will not plug straight into the Naza V2 on my Phantom Version 1.1.1. Can someone take a picture of their setup and post it if possible? I really need this to work by Tuesday of next week. Any info on hooking it up would be sooooo appreciated! Thank you very much.
  2. zenith
    Please see this video on enabling can bus port
    http://www.youtube.com/watch?v=W1nq44GDkOc
    http://www.rcgroups.com/forums/showthread.php?t=2084795
  3. OI Photography
    Clarksville, TN
    +1
    ActionChopper, your choices for adding a canbus are the method zenith linked above, or the PMU you ordered. Note that to add a canbus port manually using the instructions in that vid, your 1.1.1 will have to have the upgrade board installed (which may already be the case, if you have a Zenmuse on it as well). The upgrade board + DIY canbus is the lighter and cleaner option, but with your timecrunch you may have to use the PMU for now at least.
    Note that you do not need to use the canbus hub right now that came with your bundle. You can just plug the iOSD in to the canbus port you add yourself or via PMU, and then plug the Data Link module in to the extra canbus port on the side of the iOSD.
  4. ActionChopper
    Thank you my friends! You helped a bunch! I do not have the upgrade board so i'll just use the PMU when it gets here. You guys rock!
  5. OI Photography
    Clarksville, TN
    No problem! Let us know if you need any assistance getting it set up once it arrives.
Similar Threads - Help connecting Ground Forum Date
Standard Started disconnecting, turn off "cache to device" help? Phantom 3 Help Jul 8, 2017
Professional Need help with Samsung s6 edge plus not connecting Phantom 3 Help May 20, 2017
HELP!!! Phantom 3 pro, connecting to computer using a USB Pro/Adv Discussion Aug 27, 2016
Help - P34K aircraft not connecting to ap Standard/4k Discussion Apr 26, 2016
Help connecting 3-axis Storm32 gimbal on Vision+ Phantom 2 Vision + Help Jan 8, 2016
