Help car chase
Ok so I got a project with my friend to do a bad *** car chase
Got a open location nothing or anyone will not get in the way as this is a movie set it's closed to public
Here is where I need you help
Gps mode atti mode go same speed?
Is there a way to get more speed going front or back
Anything will help at this speed rate in gps it's slow for car chase but I have seen it done on YouTube
Maybe someone can help me here
Thanks in advance guys
Cross tracking shots may be your answer - timing is important but vehicles will be able to travel at speed.
45 degree from ahead of the vehicles may work.
You could always speed up the video a bit in post production. It will still look natural as long as it isn't sped up too much.
If you fly backwards at high speed you won't get the landing gear in the shot.
Thanks guys I'll do a test shoot in about a 1 hour see how it go I'll post a clip here
Might try also using ilovecoffee's Ground Station upgrade. I believe I read you can program multiple mission setting the settings different on each mission and run them consecutively.
wkflysaphan4
