HELP - Can't fly
Discussion in 'Phantom 2 Discussion' started by scooter339, Jun 22, 2014.
  1. scooter339
    Grand Junction, Colorado
    I need some help. I've done everything I know to do. Here's what's happening:
    The RC is calibrated. All channels normal.
    I run the P2 assistant, the Phantom shows good compass calibration and mod values. I'm in non-Naza mode.
    When I power cycle, I get two solid red lights at the tail.
    When I go back to PT2 assistant the T channel went from 0 to the left.
    I recalibrate the controller and all is well.
    But, I get two solid red lights after I power cycle.
    Additional information:
    I mistakenly had the GPS cable plugged into the Naza for an hour or so, I found the right spot on the circuit board.
    When the P2 cycles up without the RC, it flashes yellow rapidly at the tail.
    When I turn on the controller, the yellow indicators go to solid red.
    Recently I installed a new rotor being careful to match the red-yellow-black solder points to the rotor directly across from the new one.
    Is it possible the Naza is the problem?
    I'm out of ideas.
    Thanks in advance.
  2. OI Photography
    Clarksville, TN
    When you first power on the Phantom (with the controller powered on), do you see the quick repeated green-yellow-red-green-yellow-red flashes as the tones sound? Or does it immediately just go straight to the red flashes?
    Also, do I understand correctly that the red flashes you see now are always red-red.....red-red.....red-red? No more/no less, at the same pace?
  3. scooter339
    Yes, every time.
Similar Threads - HELP Can't fly Forum Date
P3 Firmware 3adv Firmware - can't update AC or RC - please help! Firmware Oct 8, 2017
Can't get my Phantom 4 to work - HELP! Phantom 4 Help Jul 30, 2017
Can't figure it out.....help needed !! Phantom 4 Pro Help Jul 9, 2017
Help! Somehow set language to Chinese and can't get back DJI Goggles May 26, 2017
Standard Can't find a pitch/roll motor. Need help Phantom 3 Help Feb 5, 2017
