Help: 4sec video latency on P3A
Discussion in 'Pro/Adv Discussion' started by Djw93, Jan 10, 2016.
  1. Djw93
    I got my new phantom 3 advanced a few days ago. did about 8 flights with it absolutely fine silky smooth video and pics, but I flew it twice today and noticed it had about 4 seconds video latency! Also quite choppy video.
    I'm using iPhone 5 recently updated to latest firmware, latest dji go app, latest firmware on p3a and remote. I also quit all apps on phone and even tried it on aeroplane mode! Still no luck.
    Anyone got any ideas?
  2. Djw93
    I tried all of those solutions and still no luck! Still getting 2-4sec latency:( is there anything eps I can try?
  3. Sagebrush
    Which iPhone 5? 5C or 5S?
    T
  4. Oso
    Oso
    Western US
    Do you a device newer than an IP5 that you can use instead? That generation device is really old for this purpose and for a while would not even allow the PILOT/GO app to install without jail breaking.
    #5 Oso, Jan 10, 2016
  5. flyNfrank
    Indy, USA
    Pretty much most all the latency or lag comes from the device being used to run the app. Your problem will only get worse as well due to the app file size increasing each time there is more processes added to it. My issues with the same type of problems you're having were resolved 100% when I switched to a new Nvidia Shield K1 Tablet for $199 shipped.
  6. Sagebrush
    I've got about the same amount of stick time with my P3A as you do. I'm running an iPhone 5S. It's smooth as silk. If I recall, the iPhone 5S is the only iPhone 5 recommended by Phantom. (and I've still got a used iPad Mini 2 coming that I picked off of eBay for $160) A bigger screen would be good.
    T
  7. Djw93
    Hmm that sucks big time. I can't really afford another tablet at the moment and I don't have a better phone. The problem is not as bad on my iPad Air, but still noticeable. It's frustrating that they don't make that clear that you need to have a very recent phone to use the app properly
  8. Sagebrush
    I think it should be fine on your iPad Air. Aren't those listed as compatible?
    Even with the problem, the video on the SD card inside the Phantom shouldn't be an issue. Correct?
    T
  9. Dirty Bird
    Glen Burnie, MD - USA
    Could it be you have a lot of apps installed & running on your device & this is slowing things down? Are apps running in the background? Did you reboot the phone?
  10. Djw93
    Nope, I delete all the background apps and even reboot the iPhone before each flight. Phone has 23gb free space too.
    Still has the latency:(
  11. Sagebrush
    Is the phone turned to Airplane Mode?
  12. Dirty Bird
    Odd that it is there now & wasn't before. Have you changed something on the phone or Phantom settings? Installed a new OS or app on the phone?
    Oso likes this.
  13. Oso
    Oso
    Western US
    The iPad Air is fine. The A7 generation Air and IP5S are listed as compatible and should work much better than an IP5.
  14. Rumbaar
    Melbourne, Australia
    Have you tried reducing the video feed to the lowest setting?
  15. Sagebrush
    Since it was working fine at first, you might try removing the cached files in the DJI GO app. Perhaps your phone is getting clogged up with video?
    T
  16. Djw93
    Rumbaar how do I reduce the video feed to the lowest setting? I'll also try and remove cached video files.
  17. Rumbaar
    Go into the Go App and HD tab, choose custom and then you'll be able to use the slider at the bottom to alter the mbps transmission rate, which effects transmission distance.
  18. tonyt76
    Changing this setting on the P3A does nothing, it is locked at 2Mbps all of the time.
  19. Mako79
    Sydney Australia
    Borrow a mates device to eliminate if it is the device you are using or if its the phantom itself.
    Also, check the hardware decoder box. If its enabled, turn it off. If its disabled, turn it on.
    No harm trying.
Similar Threads - Help 4sec video Forum Date
Help: better understanding of range vs channel availability General Discussion Today at 1:37 PM
Professional Need easy help Phantom 3 Help Today at 12:45 PM
4K editing help Video/Photo Editing Today at 1:17 AM
Advanced Pulling my hair out! HELP!! Phantom 3 Help Yesterday at 5:03 PM
Help me understand this chart... General Discussion Yesterday at 1:02 PM
