Height limit on P3P
Discussion in 'Pro/Adv Discussion' started by Okie72, Jul 21, 2015.
  1. Okie72
    I thought that the P3P could go higher than 400 ft!
  2. bimmy
    It can
    Verstuurd vanaf mijn SM-G925F met Tapatalk
  3. jryser
    Indiana
    You can go up to 500m but you cannot go higher than that, at least not with DJI Pilot app
    Sent from my PT beating heart
  4. Jbundy63
    500 meters or 1640 feet
  5. Okie72
    If I put in a value greater than 400ft it goes red then talks about the height warnings, then click on yes, than it goes right back to 400 ft.
  6. jcknows0
    Northern NJ
    Someone else on here had that issue. Do an IMU reset and then recalibrate
    Jbundy63 likes this.
  7. Jbundy63
    Are you in the U.S. There's a 400 foot FFA law here, I accidentally exceeded it one time and got no warning.
  8. jcknows0
    Northern NJ
    You won't get a warning anymore. As you much as you should respect that rule especially in populated areas and near airports, be aware the altimeter often will give inaccurate height data. I always have a fudge factor of +100ft because it gets way off the higher you go
  9. Jbundy63
    Yes I always stay under 400 feet, one time I accidentally lost visual of it and couldn't find it, it was so bright outside. I hit the RTH and thought I set that RTH height in feet but it was meters so it ended up going to around 700 before I realized it. Duh so I went back and reset it LOL
    Raph and Advexure like this.
  10. BenDronePilot
    Sure you can but not in a conventional way. Initiate an RTH and move the left stick up, you will go higher than 1640 feet.
    acherman and Ari like this.
  11. BenDronePilot
    There isn't a 400 foot "FFA" law. Who's the ffa? Football team? Just teasing. If you meant the FAA it's still wrong tho. At this time there are No enforceable laws on record regarding the operation of our little Phantom quad copters. There are however suggested guidelines as to how to fly, but nope not law.
    Ari and Jbundy63 like this.
  12. Jbundy63
    Ugh my bad LOL Yeah I try to abide by the guidelines, I figure safe than sorry
  13. TAZ
    TAZ
    I wonder if some might be being subjected to the confusing fact that in spite of choosing imperial units...the application considers and regards the entry you make in the "set maximum flight altitude field" in meters, not feet (you can see the 'm' indication next to the entry). The errors you may be getting, you'll still get if you type in 200 for example... At least for me, If I type in "121" (.equivalent of 397'), I get the warning. If I type in 120, I do not. It's important to make sure your entry is the meter equivalent of the ft you intend...even if you've set your units to Imperial.
  14. SinjinSix
    You also have to have GPS signal to set this limit. The first time I tried to change it was inside, I turned on my P3 and controller to change it but it wont let you set it higher than 120m. So the next time I flew it, I changed it right before take off to 500m. Although I never fly that high. I think 400ft is plenty high.
  15. KR Spudman
    What app can be used to set higher limits? I have a P3P that I need to fly at 600 M
  16. Colorado68
    Golden, CO
    If you try changing the height value in pilot app without being connected to the P3, then yes, it will go right back to 400'.
    With the P3 on, you should be able to change the height up to 500M and it will keep the setting.
  17. jryser
    Indiana
    I believe the SDK app which is for developers.
Similar Threads - Height limit P3P Forum Date
WARNING its the "DEATH OF DRONES" 50m height & 100m range limit if EASA pass these new RULES News Sep 29, 2016
Height limit Phantom 4 Discussion Sep 19, 2016
Max Height Limit? Standard/4k Discussion Jul 7, 2016
Height limit p3s Standard/4k Discussion Apr 12, 2016
P4 400' max height limit Phantom 4 Help Mar 26, 2016
