HDMI Out - Picture is full of blurry pixelated areas
Discussion in 'Pro/Adv Discussion' started by Cactus, Sep 30, 2015.
  1. Cactus
    Durango, CO
    I have a P3 Advanced with the HDMI board. I also have the Headplay HD's to view the live feed via the goggles, but the quality of the image/feed is so bad that it's unusable. I've spent weeks trying to troubleshoot this and so far nothing has worked. I hear reports of people using this combo and they are "blown away" by the quality. It does look good indoors, but outdoors its a dancing pixelated blurry mess.
    Does anyone else experience this too? Do you find it happens sometimes or all the time?
    I'm logging all this to try and come up with a solution over on RCG:
    http://www.rcgroups.com/forums/showthread.php?t=2507207
  2. swoopair
    Is the image the same even when the aircraft is near you, or do you mean that the image gets bad when the aircraft is a distance away.
  3. Cactus
    Durango, CO
    Distance is close for my tests. But on a flight with the Headplay goggles out about 1500ft away was the same. Difficult to look for any details on the ground and impossible to land like this.
  4. swoopair
    I have the exact same setup as you with no issues. I did, however, do the 32 Channel mod and I have plastic range extenders on my radio.
  5. Mmmope
    What was your resolution to this issue? I am having exact same problem
  6. emilford
    There is no solution to your problem. The P3 Advanced has a video download rate that is only 20% of the P3 Professional. This video download rate of 2mb/second is simply not enough to keep up with changing video content. And this limitation is in the camera hardware, not the firmware. Short of swapping out the Advanced camera/gimbal for a Professional (pricey at $520-$550) or getting a whole new P3P at $800, there is nothing you can do. By the way, the video captured on your card will be fine. It is the hardware that deals with sending that video via Lightbridge to your controller/tablet/goggles that is the problem. Sorry!! I had the same problem, and when I purchased it was not made clear that there was this important functional difference between advanced and pro making FPV all but impossible with a nice viewer.
Similar Threads - HDMI Picture full Forum Date
HDMI Module Runs Hot DJI Goggles Saturday at 3:53 PM
Professional HDMI module Phantom 3 Help Jul 14, 2017
HDMI module?! Pro/Adv Discussion Jul 11, 2017
Recording HDMI Output from Pro+ Controller Phantom 4 Pro Discussion Jul 7, 2017
Professional Wanted: P3 HDMI output module back cover Phantom 3 Help Jul 7, 2017
