HD-3D fails to tilt correctly
Discussion in 'Phantom 2 Discussion' started by n6vmo, Mar 7, 2015.
  1. n6vmo
    Lompoc, CA.
    My new Zenmuse H3-3D gimbal will not tilt correctly when I use the remote gimbal tilt wheel.
    It does pan OK, and holds position well.
    When I attempt to tilt it using the gimbal wheel, it flips to vertical and does a dance before returning again to 45deg tilt.
    Is there a setting I have missed?
    Here is a video of what it does when I attempt to tilt it....
    https://www.youtube.com/watch?v=PVkm09qvorc&feature=youtu.be
  2. Jacob
    Jacob Administrator
    Staff Member
    Thanks for the video, that saved alot of time. There is for sure something wrong. If its brand new, I would make sure the X1 lever is calibrated in the DJI software. If not, your best option may be to send it back for a replacement.
  3. Jacob
    Jacob Administrator
    Staff Member
    I have notified a gimbal expert to reply to this topic to see if he has ideas.
  4. n6vmo
    Lompoc, CA.
    Thank you Jacob.
    During X1 calibration, I get erratic movement of the X1 arrow.
    I can move the X1 arrow slowly to the right and it will reach the end point and flip back to the left side. As I continue to rotate X1 the arrow will move erratically throughout the range.
    Same issue when moving the X1 arrow to the left. Very rarely will it snap back to center when I let go.
    https://www.youtube.com/watch?v=nKkgJWIAQCE&feature=youtu.be
    If I move X1 slowly, and without reaching its limits, I can get the gimbal to tilt up and down, returning to center when released. Its when I see erratic behavior of the X1 arrow, the gimbal does its dance routine.
    It appears that the X1 control wheel it defective, since I can't calibrate X1 and get the X1 erratic movements through its range.
    Here is the X1 behavior in RC Assistant...
    https://www.youtube.com/watch?v=R0UQQ2NN69g&feature=youtu.be
  5. 750r
    Pa, USA
    How did you calibrate ?
    First in RC assistant then in phantom assistant in that order ?
  6. n6vmo
    Lompoc, CA.
    Yes, many times.
    But I went back and tried a different order of cal.
    Using the RC Assistant, I 'Started' the cal, but only ran X1 through its paces. Then 'Next' and 'Finish'.
    Then I 'Started' cal again and calibrated the joysticks only and finished. I still may have the order of operations mixed up a bit.
    Using Phantom Assistant, I noticed that X1 was not exhibiting erratic behavior and moving from -598 through 598 and the gimbal was moving smoothly in the tilt axis.
    Thanks everyone...looking forward to first flight tomorrow.
    John
Similar Threads - fails tilt correctly Forum Date
Standard Gimbal lock failsafe reminder Phantom 3 Help Aug 5, 2017
Litchi users - question on failsafe Control (Go, Litchi, etc..) Jul 29, 2017
Litchi failsafe? Software Jul 29, 2017
still trying to understand Failsafe RTH Phantom 4 Pro Discussion Jul 18, 2017
Tripod Mode fails dues to "Mission Conflict" Phantom 4 Pro Help Jul 11, 2017
