Having a pint charging
Had a nice flight, got a multi charger (one of them makes the battery stop charging on the 2nd light)
Would a multi charge all at the same time cause battery issues? They both sync and charge at the same time, both mights flash at the same time during charge...
Then they both go out of sync...
Is this a bad thing on the battery or the charger?
Neon Euc
If multi battery charger is capable of maintaining voltage at 17.5 volts, you will not see any issues. But to do this, charger should have enough capacity to feed all fully discharged batteries.
If you have an oscilloscope, connect at the charger output and monitor the waveform.
Reactions: Neon Euc
Thank you for the update. I never checked the voltage but will do
Neon Euc
