Have flight log from crash
Discussion in 'Pro/Adv Discussion' started by M1shootr, Sep 8, 2016.
  1. M1shootr
    Howard, Ohio
    I finally was able to get the flight log from my fatal crash. This was extracted from Litchi. I see no anomalies but what do I know. Now all I need to know is the best way to share online so the more experienced people here can find a cause for the crash. Here is a link I hope.
    Phantom Log Viewer - PhantomHelp.com
    #1 M1shootr, Sep 8, 2016
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Upload it here and post a link back here.
  3. M1shootr
    Howard, Ohio
    #3 M1shootr, Sep 8, 2016
  4. Meta4
    Meta4 Moderator
    Staff Member
    It doesn't help much.
    The flight record ends with your Phantom 1152 feet up and battery at 57% and no indications of a problem at that stage.
  5. M1shootr
    Howard, Ohio
    #5 M1shootr, Sep 8, 2016
  6. M1shootr
    Howard, Ohio
  7. Meta4
    Meta4 Moderator
    Staff Member
  8. flyNfrank
    Indy, USA
    Your A#1 option is to upload the DAT flight log file from the aircraft. Are you familiar with this? Some of the DAT upload info is in your updated manual. Either myself or any other flight data specialist can help guide you in this process if need be.
  9. M1shootr
    Howard, Ohio
    DJI has the aircraft at their repair facility. I've gotten different stories from the support people. One said it was pilot error but did not say what the error was. The aircraft was on a Litchi mission with a full battery and I had put no control inputs in. The aircraft just fell from the sky. This was my 82nd flight.
  10. msinger
    Approved Vendor
    Harrisburg, PA (US)
    M1shootr, where did you get the CSV file you uploaded above? It doesn't seem to be in the usual format that Litchi creates.
  11. M1shootr
    Howard, Ohio
    If you used the link in the first post try this: Phantom Log Viewer - PhantomHelp.com then click "download log files" in the upper left corner. Thanks
  12. flyNfrank
    Indy, USA
    I don't think that is what msinger was asking. He is asking about the CSV file "before" it was uploaded to the PhantomHelp Viewer.
  13. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Right -- I was able to download the CSV file you uploaded. It looks like it came from Healthy Drones though. The Litchi CSV file contains many more fields.
  14. M1shootr
    Howard, Ohio
    OK. Where am I going wrong? I know the flight is not recorded all the way to the ground. Any input is appreciated. Thanks
  15. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I'm not sure. That's why I'm asking which CSV you uploaded ;)
  16. M1shootr
    Howard, Ohio
    At this point it does not really matter. DJI has determined that due to me using a 3nd party software, (Litchi), it was my fault, no questions asked. Where is this headed? IDK. I DID ask the DJI support person if the dat files would be returned. He said yes, maybe. I'm leaning towards "maybe".
  17. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It's your call really. You asked us to help you check for anomalies -- and, then posted a CSV that contains a very limited set of data. Meanwhile, you have another CSV file created by Litchi that is chock-full of additional data points.
  18. M1shootr
    Howard, Ohio
    Ok so that is all I have been able to glean from Litchi. Refer to my previous post. It cost me $323 to have the drone replaced. DJI claims it's my fault for using a 3rd party program. What more do I need to say? I sent the drone on the same mission that was accomplished 2 hours earlier but ended up in disaster, in the exact same manner. Whether it was my fault at this point is moot. I cast doubts on using Litchi at this point.
  19. flyNfrank
    Indy, USA
    M1shootr, what Website did you use
    on the txt file
    so it could be a readable CSV file?
  20. M1shootr
    Howard, Ohio
    Healthy drones
Similar Threads - flight log crash Forum Date
P4P Crash Please help to understand flight log Phantom 4 Pro Discussion Dec 18, 2017
P3P crashed... Here is my flight log Pro/Adv Discussion Sep 5, 2016
Crash, what happened? Need to view flight logs Pro/Adv Discussion Sep 5, 2016
Need help reading flight log. My drone flew off. Believe it crashed. Hit return home. Never returned Phantom 4 Discussion Aug 22, 2016
Professional Crashed... How do I access flight logs on Litchi IOS Phantom 3 Help Jan 18, 2016
