Hard Reset on WiFi Transmitter
Discussion in 'Phantom 2 Vision + Discussion' started by Mopar Bob, Feb 26, 2015.
  1. Mopar Bob
    Connecticut, USA
    Anyone out there have a clue how to force the re-application of firmware on the WiFi transmitter? I know if you do not remove the version that is already installed, it will not actually load the new firmware. Even if it says it is doing so, it ain't. I know there is a way to do it on the naza controller by shorting out the signal terminals. This removes the firmware and then when you open the Assistant, it actually loads the firmware back up. I am trying to do the same thing on the WiFi transmitter.
    Any help would be appreciated.
Similar Threads - Hard Reset WiFi Forum Date
Advanced Actual steps to hard reset GL300C Controller? Phantom 3 Help Aug 23, 2017
Hard Reset Failure Phantom 2 Vision + Discussion Mar 15, 2016
Phantom 3 standard hard reset Standard Mar 5, 2016
Hard reset Phantom 3p is it possible ? Pro/Adv Discussion Dec 8, 2015
Hard Core Reset For P2V+ Question. Loss Of Gimbal Control. Phantom 2 Vision + Help Nov 6, 2015
