H3D2 gimbal and v3 RC question....
Hi,
I have a Phantom 2 non vision, it has an H3d2 gimbal.
I can not get the gimbal to work properly with the v3 control,
Has anyone got it to work properly? I have tried everything.
The gimbal will move both directions but comes back to 45
degrees.
Thank you
Joe
what is "v3 control" ? do you mean the NDJ6 remote control with the wheel in the upper left?
If so, in the Phantom Assistant software do you have the RC type set to standard or upgraded?
there's only 2 version of the Phantom 2 non-vision... the V1 was the original, and the V2 is the newer one with upgraded motors and comes with the new style remote.
If you had a P2v1 and have purchased a NDJ6 remote, you have to go into the Phantom Assistant software and switch the RC type to "upgrade" for the wheel to work properly. I think if you leave it as "standard" it acts like you describe
flyinghero said:
Hi,
degrees.
Thank you
Joe
Sorry Joe but the NDJ6 controller (v2) is not compatible with the H3-2D gimbal that is why it doesn't work.
oh. bummer
Yes it is the new style control NDJ6 2.4 gh.
I have set and reset everthing many times.
I suspected it was not compatible, I just
Wanted to make sure before I send it back.
I sure do like the control on the Vision+ 3.0.
Thank you QYV and Jason
Joe
Pauos31
