I had clipped a tree this past week and went down hard. I had to do a shell swap and replace an 1 motor and esc. All is back together and everything else works on the quad. However, H3-3d doesn't sit horizontal and pointing up or respond to the tilt control on the fatuba. It does respond to yaw stick. I thought it was the actual gimbal that wasnt responding to the controller due to the crash, so I got my buddy to let me test his h33d on my quad. That wouldnt respond to the tilt controll either. Is there a board in the phantom 2 that could be damaged causing just the tilt not to respond? I have linked 3 short videos to demonstrate.
Thanks for taking a look.
H33d zenmuse with no tilt control after crash
http://youtu.be/VkwtE7Jmk34
Phantom 2 attached to phantom assistant showing the x1 channel is recognizing tilt
http://youtu.be/XJXlftqrUto
Friends H33d tilt not working on my p2
http://youtu.be/UcfYhaOWjmQ
