Zenmuse H3-3D gimbal is causing Go Pro Black + to malfunction
http://youtu.be/Eg3x72q7sLk
[youtube]http://youtu.be/Eg3x72q7sLk[/youtube]
I have a Phantom 2 and a 3-axis zenmuse gimbal, I have updated the firmware with the assistant and updated the Go Pro firmware via the app.
When the Go Pro is attached to the Gimbal, inside the cradle, When I hit record on the Go pro, the Go Pro begins to beep uncontrollably, the Go Pro will freeze up, the footage is unusable, and the go pro becomes un-responsive.
I have tested three diff Go Pros, all three Go Pros work perfectly outside the Gimbal. NO issues. Once the Gimbal back plate connector slips inside the Go Pro, this issue begins.
Go-Pro Black 3 + has the wi-fi turned off. No other FPV components are installed yet. The Anti interference board is mounted via the mounting holes. I have demonstrated that in the video. The cables have been disconnected and re-seated, The Battery in the Go Pro is fully charged, the battery in the Phantom is fully charged. The Phantom RX is always on with the switched up during these test. Three different Go Pros with three diff SD cards and 3 different batteries where used in my test to factor out the Go Pro.
My guess is that the back Gimbal connector is toggling the playback/record or toggling something. My guess is that the Connector pins in the cradle are defective causing all the Go Pros to react this way.
Some clues, when I attached the Go Pro to the Gimbal, even though there is no Phantom Battery in yet, the Go Pro turns itself on? I never power it up. Wi-Fi is off.
Any Help would be much appreciated!
