H3-3D main ribbon cable
Discussion in 'Zenmuse H3-3D/H4-3D GoPro Gimbal' started by MarkRobbo, Oct 26, 2015.
  1. MarkRobbo
    Can anyone please advise where I can buy the main ribbon cable for a Phantom 2 H3-3D Gimbal. I had a heavy landing and the connection on the plug (connecting the imu) was not seated properly and when I reconnected the battery the ribbon cable burnt (smoked).
  2. jason
    Commerce Twp,MI
    Mark if you referring to ribbon that connect all three motors then that should be sent in for repair as that is one ribbon and the gimbal has to be completely dismantled to replace it. If it's the ribbon cable that connects to the USB port on you camera that you can replace yourself.
    In order to direct you to a service center your location should be posted in your personal details page.
Similar Threads - main ribbon cable Forum Date
Professional Replacement Ribbon Cable - Main Board to USB Board, controller Phantom 3 Help Apr 6, 2017
Replacement Ribbon Cable - Main Board to USB Board, controller Standard/4k Discussion Apr 6, 2017
Replacement Ribbon Cable - Main Board to USB Board, controller Pro/Adv Discussion Apr 6, 2017
Main ribbon cable break! (Not video-out cable) Zenmuse H3-3D/H4-3D GoPro Gimbal Dec 30, 2014
H3-3D replacement ribbon for gimbal main board Zenmuse H3-3D/H4-3D GoPro Gimbal Feb 3, 2016
