Hi I recently just got a dji phantom 2 with the h3-3d gimbal for my go pro hero 3 black. do you know how to adjust the gimbal i installed everything correctly and downloaded the latest firmware for the dji and the gimbal. cause when i first flew the dji phantom 2 and when i was done i reviewed the video at home it looks like when I'm turning the phantom I belive to the right you can see the landing arm of the dji to your left just curious if you found out a way to adjust that so it won't capture the arm on the go pro? and if anybody else had that problem or should i buy a bigger filter for the go pro so it won't capture the landing arm when turning flying the dji? and if you wanted to know what settings i used on the go pro it was 1080p 60fps on wide hope this info helps. thanks
