Norao said:
Hi all,
Yesterday I updated my h3-3d firmware to the latest version and then it just stopped working.
I tried to follow the steps below but when I get to step number 4, the Assistant Software says there's no update for the gimbal IMU (attached), and the current version keeps showing 0.0.0.0. Please, any thoughts?
1.As attached, try to wire it up(using a cable or conductor) that two point
2.Power on your phantom and you might find the light in the gimbal turn red
3.Connect your phantom with assistant software and there would be a gimbal IMU in the Upgrade tab
4.Remove the wire and update that IMU
5.Power Cycle
Thank you
have naza assistant up and running prior to reset. close all other software rc assistant etc.
make sure you are using the correct factory reset points. i find a pair of tweezers works best, upon power up and visually seeing red light remove tweezers immediate (no step 4) connect usb to phantom and upgrade, once prompted to power cycle remove usb and power cycle phantom.
then open rc assistant software plug in usb cable to tx and calibrate tx sticks x1 x2 u1 etc. close assistant software, unplug usb from transmitter.
open naza software calibrate tx both sticks and switches including gimble lever.
should be flying in no time.
