Any concern about both the P2 non-vision controller and Ground Station using 2.4Ghz?
Anyone using GS with a non-vision P2?
Timsytanker said:Yes. Not had a problem with it in about 15 flights using both iPad and laptop. Apart that is, from setting altitude too low when I sent it on a mission over a hill to a river.... When it came back the footage made me sweat a little! Those trees looked very close.. Lesson learnt!
damoncooper said:Can you use your controller without interfering with the data link?
Timsytanker said:When you get it try mounting the ground end and battery (if using iPad) to a non metallic pole to increase it's range, if using a PC you will need a USB extension cable. You can get over 2k away with no GS drop out that way (depending on terrain).
damoncooper said:sticking on the back of my LCD FPV monitor ( what's one more jumble of antennas back there anyway right? )
