Ground Station Latitude and Longitude
Highland, Michigan
I want to create time lapse pictures of a lake as it freezes over. I need to be in the same exact location for each photo. Can the waypoint latitude and longitude be entered manually?
Even if you are able to enter the location, there will not be consistent results unless you can program the camera to take multiple images each session. The wind alone will be a factor. Good luck!
You cant as far as I know...unless ilovecoffee figures out a way to make it possible...you could mark the spot on the ground somehow and make sure you have your bird oriented the same direction each time and just go up and shoot a few pics...then keep repeating...of course you will have to crop out some of the side image but with the vision+ wide angle you should be able to get the money shot in the middle and after processing never know the difference....at least it should work...Ive never tried it.
