- Joined
- Feb 19, 2014
- Messages
- 701
- Reaction score
- 23
Ok so I spent $500 for an ipad. Another $200 for the ground station.
What do I get?
A map and a bunch of icons.
With very little in the way of instructions.
Sorry, I was being kind. No instructions.
Not even a hint of what the icons are for.
I finally find out that the icon with the three little dots is where I can get into a menu for a few items.
Again, no hint as to what they are for.
All I want to do for now, to learn how to use it, is to use the flight simulator.
So I click on the icon for settings. Then the flight simulator button.
"Please connect to aircraft"
Ok so how do I do this?
Controller on, bird on. Right switch set to atti (center) mode.
Left switch off.
Now I find the controller button.
A box opens and says it's loading. But never loads anything.
Ground end shows red and green lights.
air end shows red and green.
on screen lights show green and blue.
Mode: n/a.
Signal strength 100%
Satellites:0. I am under a metal roof at the moment.
The item on the far right shows n/a. Is this the battery voltage?
Then, I can not always get a response from the three little dots.
Regardless if the power to the bird or anything else is on.
So how are you making yours work the way it should?
I am getting a little pissed with DJI on this.
What are the steps to make it work?
What do I get?
Left switch off.
Mode: n/a.
