Gradual spin on liftoff
Discussion in 'Pro/Adv Discussion' started by J&L, Jan 28, 2016.
  1. J&L
    J&L
    As the title suggest when I auto take off and hover all is fine. I let it stabilize do some checks. And then off I go. As I start to accend the bird will gradually start to spin. Not very fast but noticible. I have calibrated the IMU and the compass. Anything else I should check or is this normal?
  2. CCDD
    US
    I'm assuming it's not rotating 360 degrees, just a slight correction or movement. I believe this is quite normal as mine does this as well.
  3. happydays
    Warrenpoint, Ireland
    Could it be that you are applying a 'slight' degree of yaw at the same time? It's easy to do - I often do that, but by error and not by design.
    Have you calibrated the transmitter?
  4. rene van der meer
    Is it change of yaw at the same location or a slow curve?
    Could it be TBE Toilet Bowl Effect (TBE) on a Phantom 1 | DJI Phantom Forum
  5. dixter
    go to you tube and search ... toilet bowl effect DJI there are several vids... maybe they can help you...
  6. dirtybum
    I agree that you could be putting in slightest stick movements this time of year I fly with gloves the littlest ones as possible but I cannot send without spending it just slightly with gloves on. What's your logs back with the stick movements on and see if it's going over 5%
  7. J&L
    J&L
    It's quit possible I could be putting a slight movement on the stick. I'll check out YouTube and see what folks are doing. Everything has been calibrated
  8. J&L
    J&L
    I just checked the videos and it's not doing the circles. It rotating on a single axis as it goes up. I stop to hover and it stops. It's not a fast spin just noticible.
    rene van der meer likes this.
  9. rene van der meer
    There could be something wrong with the compass, the GP or the combination.
    Can you post a video of how the drone behaves?
  10. J&L
    J&L
    I'll get some video this weekend when I can test it. It only does it when I lift off and go straight up
Similar Threads - Gradual spin liftoff Forum Date
Phantom 4 spins with pontoons on Phantom 4 Help Jul 5, 2017
P4 Crashed uncontrollable spin Phantom 4 Discussion May 29, 2017
Litchi spinning at each waypoint Control (Go, Litchi, etc..) May 19, 2017
Drone spins and crashes help Phantom FC40 Help May 7, 2017
Drone spins and crashes, can anyone help? General Discussion May 3, 2017
