gps
Discussion in 'Phantom 2 Vision + Help' started by wild willy, Jun 1, 2016.
  1. wild willy
    i need a used gps module for a phantom 2 vision cant not get one with the connector for the compass wiring hariness to plug in anyone who can help contact me , thanks
  2. J Dot
    Sarasota, FL. USA!
    Hello
    Just to let you know, either GPS WILL WORK, if you use newer style GPS ( with NO compass port ) just plug compass to mainboard ( in COMP connector ) or old style where compass hooks to GPS. But either is fine with no mods, only issue I found was OLD style GPS, with anti static compass ( wire too short ) so just pop off cover, replace white wire with longer stock grey wire works perfectly!
    Hope this helps!
    J Dot
    :cool:
    Mark The Droner and dirkclod like this.
  3. Mako79
    Sydney Australia
  4. Mark The Droner
    If the problem is a cracked antenna, you can replace it for around four dollars.
Similar Threads - gps Forum Date
No GPS Standard/4k Discussion Thursday at 7:51 PM
Gps signal lost Phantom 4 Pro Discussion Aug 10, 2017
Upgraded GPS Antenna-10 Satellites Phantom 2 Discussion Aug 9, 2017
Standard GPS and Compass pinout Phantom 3 Help Aug 9, 2017
P4P losing GPS temporarily! Phantom 4 Discussion Aug 9, 2017
