GPS Signal low
Discussion in 'Pro/Adv Discussion' started by ScottNoel, Jan 17, 2016.
  1. ScottNoel
    Tried to use follow me yesterday and when i would try to engage it would pop up and say GPS signal on device not avaiable or low.. Any ideas?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    What kind of mobile device are you using?
  3. ScottNoel
    ipad mini with retina
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The cellular or Wi-Fi only model?
  5. ScottNoel
  6. msinger
    Approved Vendor
    Harrisburg, PA (US)
    That's the problem. Only the cellular models have GPS.
    If you don't want to purchase a new mobile device, you could get a Bluetooth GPS receiver.
  7. ScottNoel
    i thought in follow me mode, it followed the signal from the controller? didnt think the tablet or phone had anything to do with it..
  8. fort384
    It's all about the location of your mobile device. The external gps units are compact and work well through blue tooth. I use one with my iPad flying airplanes. Will be more than accurate enough for what you'd like to accomplish and it'll fit reasonably well in your pocket or you could Velcro to your controller
  9. ScottNoel
    what wouold be the best external GPS to get?
  10. msinger
    Approved Vendor
    Harrisburg, PA (US)
    You can find a list of commonly used external GPS receivers here. Based on price and the fact that it can connect to both GPS and GLONASS satellites, I would get the Garmin GLO.
  11. fort384
    I use a Dual but the Garmin is probably just fine as well! They are all pretty simple once paired. Just turn on and wait a few seconds. Just another thing to remember to charge though :)
  12. Oso
    Oso
    Western US
    Hi Scott. If you have time, check out this post for a high level overview and some helpful notes to add to what has been noted above already.
    Tablets and phones that work well with DJI GO | Page 21 | DJI Phantom Forum
Similar Threads - GPS Signal low Forum Date
Follow Mode and Weak GPS signal Standard/4k Discussion Jan 2, 2016
Flying in Low GPS Signal Environments General Discussion Mar 10, 2015
Gps signal lost Phantom 4 Pro Discussion Aug 10, 2017
No GPS signal , how to calibrate gps ? Phantom 2 Vision + Help Aug 9, 2017
Stronger gps signal Other DJI Multi-Rotors Jun 8, 2017
