GPS not working after re-shell
Discussion in 'Phantom 2 Vision + Discussion' started by Kentigern, Jul 26, 2014.
  1. Kentigern
    I bent my brand new Vision + on its second flight. I have re-shelled it but now the GPS is not getting a lock. Is there anything I can try to revive it? Or should I just bite the bullet and reach for the credit card?
  2. cahutch
    Sonoma County, CA
    I assume the GPS connector is plugged in and secure.
    Other than that, did you keep the RF shielding that covered the GPS module on the old shell?
  3. Kentigern
    I did keep the RF shielding. I basically stripped the old shell and re-fitted it all in the new shell. Pretty straightforward once I had worked out that the RC unit was glued to the motherboard.
  4. Dirty Bird
    Glen Burnie, MD - USA
    Did you plug everything in correctly? Plugs correctly oriented? Was the GPS module cracked from the incident that required the re-shell? Try reseating the connectors and make sure they are correctly oriented.
  5. cahutch
    Sonoma County, CA
    What does the app report for GPS signal? A few satellites but not enough for a lock? Or Zero satellites?
    If a few, it's probably a shielding problem. If Zero, probably a connector.
  6. Kentigern
    The app says zero satellites, in fact the satellite icon is grey. The connector from the GPS unit is not a great fit into the socket marked GPS on the main board but they are a match...
  7. Kentigern
  8. bergenfelter
    Might be kind of a dumb point - so excuse me - be sure when you install the GPS array the antenna is pointing skyward and the chips and stuff on the round board are facing down.
  9. DownunderPhantom
    Grafton, New South Wales, Australia
    Are you sure that the GPS connector is in the correct way, it should only be able to go in one way but you did say "not a great fit"
  10. Kentigern
    Thanks for the advice everyone. I am pretty sure I connected it correctly, so I have ordered a new one. My crash was only a little one but it was enough to bend the shell, and It seems it was enough to trash the GPS module :(
  11. Kentigern
    Just received a new GPS module, which has made no difference at all. Gah!
  12. Mako79
    Sydney Australia
    maybe your app is faulty. My android app once showed 0 sats. I then used the iphone and sats showed 7. Switched back to andriod app and it was fine again. I'm on the new 3.06.
    go outside, turn on the transmitter and turn on the phantom and see if you get green lights.
Similar Threads - GPS working shell Forum Date
iPhone gps not working Standard/4k Discussion Sep 4, 2016
Will the P2V+ Fly without the Camera with WiFi & GPS working? Phantom 2 Vision + Help Feb 1, 2016
Advanced GPS not working with Samsung Tab A Phantom 3 Help Jan 18, 2016
GPS has stopped working!!! Phantom 2 Help Aug 25, 2015
Humble seems to be tilting to the side and gps not working with fpv Zenmuse H3-3D/H4-3D GoPro Gimbal Jun 23, 2015
