Several times now I have experienced what seems to be a GPS system failure mid flight. The OSD suddenly shows zero satellites, the flight mode jumps from GPS to ATTI, and the speed indicators are zero'd. I believe the nav diamond also disappears. It happened to me for about the fourth time in several months this morning. First symptom was no longer holding lat/long position, then when I went to correct, I noticed ATTI in the OSD. Once I realized GPS was out, it seemed to fly ATTI mode normally, and with about 10kts wind, was a mild challenge to bring home, but nothing to panic about. I waited in the air a bit to see if the GPS would reboot and find sats again, but no joy. I landed, powered down the P2, then immediately powered it back up on the same battery, and GPS was normal. Quick lock on plenty of sats, then I flew the rest of that battery, and then two more full batteries without incident. The first time this GPS outage happened to me a few months back, I opened the shell and checked for any obvious signs of loose connections, solders, etc. Nothing obvious.
If this is a problem that a rookie experiences in any degree of wind, I could imagine it being experienced as a "fly away", though in fact it's more of a "drift away". Though apparently in this failure mode it responds just fine to stick input.
I've concluded this is a shy bug that could show up at any time on any flight, and that I can't always count on HomeLock to be there for me. In such events, I either need to nav home visually or through FPV, or force RTH.
Silver lining is that it shouldn't toilet-bowl when the GPS is out.
Curious if others have seen your GPS system [only] give out in flight.
Kelly
Kelly
