GPS does not work
I have a DJI-Phantom and recently I bought a Zenmuse DJI-board and an update. After doing the installation the Phantom works normally, including Zenmuse, but the GPS stopped working. I opened again the Phantom and confirmed all connections, everything looks correct but the GPS does not work. What could it be? could you help me?
thank you,
As a start heres some questions that may aid in troubleshooting yourroblem:
What happens when you power up outside under open skies? Do you get 3 then 2 then 1 then no red flashes after warmup as GPS satellites are found? If not, what do you get? Also what firmware are you running? Do you get any errors when connected to the NAZA assistant software via USB?
I suggest recalibrating everything from transmitter itself, reload Phantom parameters, check sticks in DJI Assistant, advanced IMU calibration, and compass calibration, just everything. This may not help, but can't hurt either. There have also been reports of needing to turn IOC off to complete calibrations.
Steve
thank you,
thank you,
Check wire tightned from GPS to Compass unit. As they work together, a loose connection reports no GPS at all.
i have the same problem... doesn't work... i'm going to put a new one gps module...I have the problem during a flyght...the the `PPM receiver does'nt work too...
when I call him, even in the open, it blinks yellow twice. I updated the firmware to 4.0 and recalibrated all parameters in Software Assistant V1.8. No Software has announced that GPS is off. The configuration of the rod is ATT, ATT, NORMAL. The IOC is disabled and not available (GPS is needed). I do not know what I do!
cgarner1
