The simplest way is to take a photo looking straight down and look at the exif data for the photo.Is there a way that I could hover above a point and find the long. and lat.
I think the Go app does the same thing in a way, (not real-time). After the flight you can play back the flight in your device log and it's there on the bottom.
Never really checked if these coordinates were good or not, just know they were there on the display. I checked those numbers you posted and come up with about 12 miles apart, if you typed them correct. Personal I use a Trackimo, for backup. And also know that Litchi has an option that pinpoints the last know location it recorded so you can walk to it. There was another post I just read where the guy did use the Go app and Google with coordinates from the app and found his drone. I'll see if I can find it.I found this device log after my phantom auto landed in a field due to low battery. However, the coordinates at the bottom only changed slightly between takeoff and landing (22.04,-159.74 at takeoff and 22.11,-159.55 at landing) even though it was found a good 150' away from it's takeoff point. So that did me no good. I even took those coordinates and punched it into google maps and was told it was about 1/2 mile away, which it was not. Any suggestions?
Found it on the DJI forum: RTH WHEN RC IS DISCONNECTED ?Never really checked if these coordinates were good or not, just know they were there on the display. I checked those numbers you posted and come up with about 12 miles apart, if you typed them correct. Personal I use a Trackimo, for backup. And also know that Litchi has an option that pinpoints the last know location it recorded so you can walk to it. There was another post I just read where the guy did use the Go app and Google with coordinates from the app and found his drone. I'll see if I can find it.
Hello, and welcome to the forum!I found this device log after my phantom auto landed in a field due to low battery. However, the coordinates at the bottom only changed slightly between takeoff and landing (22.04,-159.74 at takeoff and 22.11,-159.55 at landing) even though it was found a good 150' away from it's takeoff point. So that did me no good. I even took those coordinates and punched it into google maps and was told it was about 1/2 mile away, which it was not. Any suggestions?
Have you done this before? Possibly go into detail about the steps it takes to get this accomplished? I may try this tomorrow as long as I can get a time column associated with each lat/long entry.Litchi can also record realtime GPS coordinates while recording video and save it as an .srt file. When the video is played back, the GPS coordinates appears as a subtitle and change as you move the aircraft.
