Product Review
Today, I am reviewing and providing in depth details on Go professional cases DJI phantom 3 limited edition storm backpack.
http://goprofessionalcases.com/shopcases/dji-phantom-cases/gpc-dji-phantom-3-backpack.html
Disclosure : I am not employed or affiliated with GPC.
I am a frequent international traveller and I normally like to hike and bike to remote places to capture those magic moments.
DJI's Phantom 3 fit this role perfectly, however, I've found that the DJI turtle shell case was limiting in term of storage ability for my use so I recently ordered this case on the recommendation of my good friend Aldryn Estacio.
Technical details:
The GPC Pack is made in the USA, housed in the 5.11 Rush 72 backpack as used by military and weekend warriors.
This backpack is engineered to be a full featured 72 hour bag to provide ample space for all the gear and accessories while remaining rugged and reliable enough for extended excursions or tactical deployments. The fabric material is made from highly resilient, water repellent 1000D nylon construction to keep the internal gear safe and dry in any environment.
The inclusion of MOLLE / TacTec System[emoji769] compatible web platform keeps all your gear within easy reach. When it comes to storage, this backpack delivers; dual zippered front and main compartments, an admin organizer pocket, an internal hydration compartment, an easily accessible shove-it pocket, and a fleece-lined sunglass pocket keep your loadout organized, stable, and secure over rough terrain. I like the fact that it has 10 pockets and 14 sub pockets which allows limitless storage options. I can carry all the equipments I'd ever need in this back pack and carry on with me onto the plane making checking in and out of airports much faster. With the DJI turtle shell, I had to pack a second separate bags for all my other essential accessories on my international travels.
Other great features includes:
Contour yoke system with grab and go handle.
Rugged, self-healing YKK[emoji768] zipper hardware.
Integrated drainage grommet.
Adjustable dual density closed-cell foam shoulder straps.
Cinching waist strap and dual compression straps.
Dual-zippered front and main compartments with molded grip pulls
Multiple integrated organization pockets
Admin organization pocket to store maps, pens, and documents
Fleece-lined sunglass pocket
Internal hydration compartment with hangers and toggles
GPC tailored this case to provide full protection and safe storage for the P3 via the addition of their custom multilayered foams with different properties.
GPC custom foams are unique in that they are cut by water jet to obtain high quality and detail. The foams are not die cut and no sharp corners. The blue surface foam is 4 lb Blue MDL for added durability & brand recognition. The Black foams layers are 1.9 lbs Soft Cell PE, it has smaller bubbles therefore not abrasive to product going in, other companies use 2.2 or 1.7 lbs, each of these are more abrasive therefore higher risks of scratching the product. In addition the soft cell is twice the cost over the regular 2.2 & 1.7. At the base of the main cavity, convoluted foam (similar to those found in sound studios) is used to stabilise the gimbal, this helps to reduce movement during transport, therefore take the stress off the gimbal and shock absorbers.
The other design feature of the GPC backpack is that the P3 is designed to sits proud for easy removal and better presentation. With the batteries this allows for thicker walls between cavities and help reduce weight and overall size of the backpack. GPC supplies special cover to protect the motors. Unfortunately, these were missing from my package. I contacted support and within 4 hours they were promptly dispatched to me. Can't ask for better after sales customer service.
Compared to other backpack on the market for the P3, GPC limited edition storm case is very reasonably priced considering all the features on offer. Best of all, GPC packs are Made in the USA and comes with a lifetime guarantee.
GPC ships international as well and I found shipping to Australia was reasonably priced and fast as well.
For the ultimate in stealth professional look, the GPC pack will be my travel companion from now on.
Specifications
Exterior Length 23 in
Exterior Width 14 in
Exterior Depth 9 in
Interior Capacity 894 cu in
Lynh Phan
Technical details:
Specifications
Exterior Depth 9 in
Lynh Phan
