GoPro4 LightBridge Problem
Discussion in 'DJI Lightbridge' started by kelleyre, Oct 6, 2014.
  1. kelleyre
    Just got the GoPro 4 installed on my Phantom 2 and everything seemed to be going great until I hit the rec button on the gopro4 and the video and osd data going to my hdmi monitor froze.
    Stop recording and it all starts working again. this is at 2.7k 48fps setting. If I set the gopro4 to 1080p 60fps it works great. I have found some info after looking around on the web that the output
    from the hdmi on the gopro4 is at a lower resolution until the record button gets pushed and then the hdmi outputs the resolution that was set in the camera, in my case 2.7k 48fps or 30fps,which i guess the lightbridge can't down convert?.
    This was not a problem with the gopro3+ set at 2.7 30fps.
    I hope this gets fixed as I want to record to the camera at all the cool new resolutions but still monitor at 720 or 1080 on my lightbridge hdmi output.
    Isn't it allways something with new stuff
  2. gword256
    Springfield, USA
    Have you posed this problem directly to GoPro? Seems like something they could roll into a future firmware update.
    Just a thought.
  3. Mikegwalk
    Peoria IL
    Just spoke to a Gopro reb (way easier to get a hold then a DJI rep)They told me there is a software update coming in the next two weeks to allow you to have FPV on Lightbridge while recording at 4k or anything after 1080p 90FPS. Hopefully this is true.
  4. kelleyre
    Check this out. This is in the LightBridge manual.
    Its shows that no matter what resolution your using to record. the hdmi out is some version of 1080p or 720p.
    Still hoping that this gets fixed.
Similar Threads - GoPro4 LightBridge Problem Forum Date
Gopro4 LightBridge FPV Problem FPV (First Person View) Oct 8, 2014
GoPro4 LightBridge Problem General Discussion Oct 6, 2014
Compatability P2+Gimbal H4-3D+Gopro4 Zenmuse H3-3D/H4-3D GoPro Gimbal Dec 8, 2016
Dropping in my 30+ highly edited Phantom 2 Videos Gopro4 Black - what do you think? Photos and Video May 19, 2016
adding a gopro4 to rear of v+ Phantom 2 Vision + Help Nov 19, 2015
