Just got the GoPro 4 installed on my Phantom 2 and everything seemed to be going great until I hit the rec button on the gopro4 and the video and osd data going to my hdmi monitor froze.
Stop recording and it all starts working again. this is at 2.7k 48fps setting. If I set the gopro4 to 1080p 60fps it works great. I have found some info after looking around on the web that the output
from the hdmi on the gopro4 is at a lower resolution until the record button gets pushed and then the hdmi outputs the resolution that was set in the camera, in my case 2.7k 48fps or 30fps,which i guess the lightbridge can't down convert?.
This was not a problem with the gopro3+ set at 2.7 30fps.
I hope this gets fixed as I want to record to the camera at all the cool new resolutions but still monitor at 720 or 1080 on my lightbridge hdmi output.
Isn't it allways something with new stuff
Check this out. This is in the LightBridge manual.
Its shows that no matter what resolution your using to record. the hdmi out is some version of 1080p or 720p.
Still hoping that this gets fixed.
Mikegwalk posted this yesterday
Just spoke to a Gopro reb (way easier to get a hold then a DJI rep)They told me there is a software update coming in the next two weeks to allow you to have FPV on Lightbridge while recording at 4k or anything after 1080p 90FPS. Hopefully this is true.
