GoPro to back of PV2+ Gimbal?
Discussion in 'Phantom 2 Vision + Discussion' started by easydubsit, Sep 14, 2014.
  1. easydubsit
    Has anyone played with the idea of attaching a GoPro to the back of the stock gimbal? In essence, running both cameras, one facing forward and one facing the rear.
    In theory, it would only affect the weight during it's yaw corrections.
    Would the extra weight break the gimbal?
    I was thinking of using some 3M adhesive or 3M velcro (industrial strength). I'm certain the gopro wouldn't go anywhere, but don't want to break the gimbal.
    Thoughts?
  2. npalen
    Kansas
    Interesting idea! Would be easy enough to try. (very gently)
  3. DownunderPhantom
    Grafton, New South Wales, Australia
    Um.. hello, the gimbal was designed for the camera it has and it is fragile as it is.
    The added weight would,
    1: Change the CG (center of gravity)
    2: reduced flight times
    3: make the gimbal more fragile
    4: add more resistance to the gimbal motors.
    5: the gopro would have virtually no stabilisation
  4. easydubsit
    Changing the CG wouldn't necessary matter, theoretically, as the gps position hold would still hold it's position (imagine a steady wind blowing the craft, all the same to the computers)
    Reduced flight time would be expected
    Stabilization would still be controlled during yaw , just not pitch and roll. It would also benefit from the anti-vibration mounts.
    the only added resistance would be to the upper most motor that corrects the camera yaw.
    Has anyone attempted this before?
  5. DownunderPhantom
    Changing the CG does matter, I have modded my FC40 with gimbal and gopro and if you do not have the CG right it is a real pain to fly.
    I have also mounted the data link to the base of the Vision plus and even though it is lighter than a gopro I can definitely feel the change in CG by the way the bird flies. The stronger the breeze, the more
    it is noticeable.
    The anti vibration mounts are also only designed to carry the original gimbal and camera, more weight would stretch them and possibly make them more prone to
    pull out. Jello effect may also be a problem.
    stabilization, hmmm, would be like flying in FPV mode without the pitch and roll stabilization.
    But they are only my thoughts, try it and I would be interested with the results. A video of both forward and rearward facing videos would be interesting.
    Happy flying
Similar Threads - GoPro PV2+ Gimbal Forum Date
gopro camera mounting in PV2+? Phantom 2 Vision + Discussion Apr 18, 2015
Mounting GoPro on PV2+ Pics Attached Photos and Video Aug 28, 2014
Pros & Cons of PV2 w/ GoPro versus PV2+ Phantom 2 Discussion Jul 12, 2014
Question: PV2/GoPro vs PV2+ General Discussion Jul 8, 2014
GoPro hero 5 on a dji p4? Phantom 4 Discussion Jan 13, 2018
