GoPro Hero3+ black
Discussion in 'Off Topic' started by TomasB, Dec 4, 2015.
  1. TomasB
    Canada
    Not feeling very confident at the moment with GoPro support. My hero 3+ black recently developed colder weather issues where it shut off at 0 degrees Celsius weather. They first say oh it's battery, then oh it's sd card and finally after numerous communications they say oh it's normal.....wow!
    I've replaced batteries, kept warm in pocket . Also swapped sd cards. Same problem persists.
  2. jason
    Commerce Twp,MI
    The problem you are having is not caused by the battery, sd card nor is it normal. Have you update your camera to v03,03? Turn on the camera while looking at the bottom of the window and you'll see what version the camera has. I have flown in -6.6 celsius with no ill effects.
    What gimbal are you using and is this phantom 2? List all the gear you're using on the quad.
  3. MarqueGlisson
    Pacifica, Ca.
    Great info!
  4. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
    I have flown mine in subzero temps without issue. Sounds like something else. Those batteries will give you issues if they are not kept warm prior to use but you said you did that. Do you get the same issue if you turn on the Gopro not mounted to the quad in the same temps?
  5. TomasB
    Canada
    Jason
    Thanks for the response. I'm using the H3-3D gimbal in a Phantom 2.
    The firmware is an older version 2.0 . I haven't updated recently after hearing about latest firmware cancelling out fpv thru usb.
  6. TomasB
    Canada
    Yes same issues mounted or unmounted and Phantom powered up and not powered up and also ribbon plugged in and not. Same issue. Very frustrating as I have never had this problem before in much colder weather . Nothing has changed same setting and setup.
  7. jason
    Commerce Twp,MI
    Have you a second battery? If not get one and test it again.
  8. LuvMyTJ
    Staff Member
    Yeah, if nothing else has changed the only consumable in the camera is the battery so maybe it has nearly reached the end of it's usable life and the cold temps are amplifying the weakness.
  9. TomasB
    Canada
    Yes I just recently purchased a new one because my first thought was it's the battery.
  10. TomasB
    Canada
    And yes it was tested also with new battery.
Similar Threads - GoPro Hero3+ black Forum Date
p3 camera vs gopro hero3+ black Pro/Adv Discussion May 26, 2015
GoPro Hero3+ black HD lens modification General Discussion Jul 26, 2014
Remote Control Use w/GoPro Hero3+ Black & Phantom 2 Phantom 2 Discussion Jun 25, 2014
Remote Control Use w/GoPro Hero3+ Black & Phantom 2 Phantom 2 Vision Discussion Jun 25, 2014
Reducing GoPro Hero3+ Black barrel or lens distortion General Discussion Oct 7, 2013
