GoPro extended arm mount
Discussion in 'Photos and Video' started by Pyroscott, Jun 27, 2013.
  1. Pyroscott
    I decided to try mounting my GoPro to an arm attached to the bottom of my Phantom. I wanted to see the Phantom in flight. The first flight, GoPro in its case, was not good. I did a ground loop as there was too much weight on the end of the arm. I adjusted the arm length, by moving it inward and added a little counter balance on the other side. The Phantom sat level on the ground. It took off and flew nicely. It did go slower when flying backwards.
  2. Pyroscott
    Re: GoPro extended arm mount video
    Here is a video from flying with that mount.
    [youtube]http://www.youtube.com/watch?v=WrI54MVDpPs[/youtube]
  3. Guy22391
    Wow!! Do u have a video on how you made the mount?
  4. Pyroscott
    I didn't make a video on putting the mount on. But it is relatively simple.
    First, get a carbon fiber driver, take it on the golf course and hack away. When you break the driver, cut it in about the middle.
    The rod is just ziptied to where the landing gear and body join. I still had the handle on the club.
    My first attempt at mounting the rod, the balance of the copter was way off. When I took off, I did a ground loop and landed upside down.
    I moved the club in about 5" to create a counterbalance when the gopro was mounted to the end of the stick. I had to add a little weight(2, 1/2"x1" Bolts) also to that side. The copter should be balanced on a flat surface with everything attached.
    My next flight, I'm going to raise the gopro a little higher so the phantom is at the bottom of the frame.
    I can take som closer photos if needed.
Similar Threads - GoPro extended arm Forum Date
How to get extended range for GoPro WiFi Phantom FC40 Discussion Jun 7, 2014
GoPro hero 5 on a dji p4? Phantom 4 Discussion Saturday at 11:30 AM
GoPro laying off 200-300 hundred from drone div.. News Jan 5, 2018
EDINBURGH Day of Time Lapses / GoPro Time! Off Topic Jan 1, 2018
GoPro Hero 4? Phantom 2 Discussion Dec 30, 2017
